Old 10-16-2018, 10:50 PM
lr172 lr172 is online now
Default What size solder sleeve
I would like to use solder sleeves for attaching pigtails to shielding, but have no experience with them. Can anyone tell me which size sleeves to order for 2 and 3 conductor shielded tefzel?
N64LR
RV-10 in progress
Old 10-17-2018, 01:32 AM
amerkarim amerkarim is offline
Hi Larry,
I find they come in 4 colours:
White are very thin and useful for joining 2 thin wires (AWG 24 to 20)
Red are bigger and for joining 2 thicker wires (20 AWG to 14 AWG)
Blue I use for joining shielding wires in 2 / 3 / 4 cables
Yellow are too large for most things but occasionally I use them when I have lots of wires bunched together
I would get blue ones for shielding and reds for general purpose wire joining.
Happy soldering !!
Amer
Old 10-17-2018, 02:15 AM
rv8ch rv8ch is offline
Default Red and Blue
Agree with Amer - Get a bunch of Reds and Blues. They are really great.
Mickey Coggins
http://rv8.ch
Old 10-17-2018, 02:43 AM
andyrv andyrv is offline
Default Solder sleeve with integral pigtail
Take a look at Steinair. He has the solder sleeves in different sizes for shielded wire with the pigtail already built-in to the the sleeve (also without the pigtail).
They work very well to terminate the shielded wire.
https://www.steinair.com/?search_cat...sttype=product
Also see the solder sleeve video on this page for installation instructions. A lot of great wiring videos/tips on this page.
https://www.steinair.com/documents-and-support/videos/
Andy
Andy Cobb
RV-7A
MO00 & KLXT
Old 10-17-2018, 07:04 AM
Carl Froehlich's Avatar
My opinion so take with a grain of salt. I view solder sleeves as a waste of money and clunky. Soldering a pigtail to a braided shield wire and covering with a piece of heat shrink is a very simple task.
Old 10-17-2018, 08:12 AM
That is what I did on the 6, but this G3X system wants a LOT of shielded wire (many terminated on both ends) and I thought this would save the hassle of soldering in place in the plane.
N64LR
RV-10 in progress
Old 10-17-2018, 08:14 AM
Andy
Looking at the stein site, each of the different sizes is blue Do you know the fractional size of the "blue" sleeve that you recommended 2-3 conductor?
The blue TE connectivity one's that I had identified at Digikey were .180" Does that sound right?
N64LR
RV-10 in progress
Old 10-17-2018, 09:17 AM
Walt's Avatar
Walt Walt is offline
I use HML-8 for 2-3 conductor shielded wire.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
RV7A built 2004, 1700+ hrs, New Titan IO-370, Bendix Mags
Old 10-17-2018, 09:45 AM
Raymo's Avatar
Raymo Raymo is offline
ACS option.
SOLDERING SLEEVE 1/4" 11-07903
I agree with Carl on the use of shrink wrap. Easy and less $$$. I prefer the marine grade shrink wrap on Amazon vs ACS.
Ray
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
All lines by TSFlightLines
Old 10-17-2018, 10:44 AM
JonJay's Avatar
JonJay JonJay is offline
When your laying on your back, feet up in the air over your seat backs, under the panel, it is a viable option.
I agree with Carl otherwise, but I have a couple sleeves where putting a heat gun on it was much easier than trying to solder.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
