Old 01-22-2018, 06:15 AM
RV3Kev RV3Kev is offline
Default Firewall Recess for
Iím starting work on my firewall soon and I would like to keep open the option of using a CS prop. To do this itís necessary to add a RV7/9 type recess into the firewall.
Does any have any information on the correct location on the firewall?
Old 01-22-2018, 08:40 AM
Scott Hersha Scott Hersha is offline
If it's like the RV4, you'll need to modify the firewall where the bump out is for your rudder pedals - to make room for the aft mounted prop governor. This area would be bumped in between your rudder pedals. Vans has plans for this, and maybe even kit parts (stainless steel).
http://vansaircraft.com/cgi-bin/stor...duct=fw-recess
SH
RV-8
Cincinnati, OH/KHAO
Old 01-22-2018, 10:04 AM
I went through this on mine.
I bought both the F-601K-1 recess and the one for the RV-4. The RV-4 recess is completely useless for the RV-3 since the -4 has a far different firewall shape. The F-601K-1 recess was not tall enough so I had to add on to it.
I described this part of my construction iin my blog here on VAF, in posts 241 through 245. I'm repeating some of the photos below. If you're only adding the governor, the stock recess ought to be fine. Adding the filter changed things. Although it would be heavier, a remote oil filter might be appropriate here.
Here's what I learned for the locations of things:
This is the back of the engine:
The box I built:
It was so handy having the engine on hand before I started the firewall!
One thing that I'm not looking forward to is maintenance with the recess. While Andy Hill assured me that the filter can be changed, I think that both that and cleaning the recess might be difficult.
RV-3B, now skinning the fuselage
Old 01-22-2018, 11:35 AM
sf3543 sf3543 is offline
Kevin
I also used the 601K-1 recess and it works fine without being modified.
The engine is an O-320-D1A with the angled oil filter adapter and MT governor using VAN's bracket. The bracket needed minor tweaking to work.
I mounted it centered on the FW with the top of the recess riveted to the top horizontal FW angle.
I have some detailed pictures but don't want to take the time to figure out how to post them.
Email me if you would like the pictures.
sf3543 at sbcglobal dot net
Good luck
Steve Formhals
RV6, RV8 (2), RV12 & RV3 99% done.
A&P, Tech Counselor & Flight Advisor
Old 01-23-2018, 04:44 AM
randylervold's Avatar
randylervold randylervold is offline
moderator
I'm sorry I don't have the exact dimensions, but you could probably extrapolate from the photo at the top of this page...
http://www.romeolima.com/rv-3.com/rv...llforward.html
Randy Lervold
RV-12iS, empennage/tailcone, wings & fuse on order
RV-3B, first flight 2007 - sold
RV-8, first flight 2001 - sold
