Old 03-24-2018, 10:43 AM
sblack sblack is offline
Default Mgl efis pitot static adapters
The mgl efis comes with these adapters to hook up the pitot static lines:
http://www.mglavionics.com/kb/articl...-adapters.html
They say that the adapter accepts standard 3/16" plastic lines. I have not found any standard lines with that ID. I have tried 1/4" polyflo and the 1/4" tubing from Stein. I think their wall thickness is a bit greater than 1/32" so the adapters only go a short way into the libe. I have tried dish soap and heating the lines but it diesn't seem to make a solid attachment. What lines are other people using and should the adapter go in all the way up to the end of the taper?
Scott Black
RV 4, O-320, wood prop, MGL iEfis Lite
VAF dues 2019
Old 03-24-2018, 02:06 PM
FasGlas's Avatar
FasGlas FasGlas is offline
I didn't use plastic, I used vinyl hose. Might have been 1/8", like fish tank hose. All my brass fittings for pitot and static matched just right.
Old 03-24-2018, 03:01 PM
Do you think that softer stuff will work with the quick disconnects from steinair?
Scott Black
VAF dues 2019
Old 03-24-2018, 05:28 PM
FasGlas's Avatar
I don't know why not, there's very little pressure in these lines. They are very flexible.
Old 03-25-2018, 06:47 AM
merlin3 merlin3 is offline
I heated the lines with a heat gun and was able to get them on the adapters but im still not happy with it even though its been fine for a year.
Justin
Rv-6, o360, whirlwind cs prop, old paint and panel
Rv-4,o-320,prince prop, mgl avionics screens - sold
Old 03-25-2018, 08:22 AM
DNeufeld DNeufeld is offline
You might try Tygon fuel tubing.http://www.chiefaircraft.com/catalog...?q=fuel+tubing Chief Aircraft stocks it for their model stuff. Very flexible hangs on to the barb well and doesn't kink easy. After sliding the tubing on, give it a wrap or two with .025 safety wire around the diameter. There is silicon fuel line for glow fuel engines but it cuts easier and is more flexible than Tygon. Go down the page and you'll find nice barbed adaptors...
