Go Back   VAF Forums > Model Specific > RV-4
Old 12-27-2016, 04:12 PM
Sixgun Sixgun is offline
Default RV 4, 0- 320 oil filter adapters
I am wanting to do away with the oil screen and install a oil filter adapter and filter on my 0 320 B3A engine. Its an older conical mount, and I'd like to know the best one to get and the length of the spacer I'm going to need to clear the engine mount. If any of you folks could steer me in the right direction on this installation, I'd be most appreciative of your advise.
Thanks,.. George
Old 12-27-2016, 04:46 PM
Alternatively, you can probably use the Lycoming oil filter adapter directly. I have one on the O-320 for my RV-3B and although I had to adjust the recess to make it fit, this it does. You can read about it in my VAF blog here, starting with post #242 and going through post # 245.
I understand that the RV-3B firewall is 4" closer to the engine than the RV-4 firewall.
Dave
Old 12-27-2016, 05:52 PM
Mark Albery's Avatar
Mark Albery Mark Albery is offline
I have a similar set up on my -4. It uses the Casper Labs adapter with the smaller motor-sport filter. This gives easy access for changing and plenty of clearance .
Old 12-28-2016, 10:11 AM
dsmith1055's Avatar
dsmith1055 dsmith1055 is offline
Default RV4 conical mount filter
Several years I bought a Casper oil filter adapter for my conical mount O-320 RV4. It would not work due to interference from the conical mount. Casper sent me several different configurations in an effort to solve the inteference problem. None would clear the mount. Casper was very helpful and refunded my money when they were unable to find a workable solution. I believe your only solution is a Lycoming Filter mount. Cost of the Lycoming filter led me to abandon the effort. Good luck with your efforts.
Dwight Smith CFI
Flight Advisor - Tech Counselor
Old 12-28-2016, 12:35 PM
Thanks Dwight, I keep looking at it and I'm not encouraged by what I see. Its just overhauled and I wanted to go with a filter but not rebuild and plumb the engine accessories to do it. Maybe I should look into remote locations... George
Old 12-29-2016, 08:19 AM
659JR 659JR is online now
Default oil filter adapters
The prices of the adapters have come down quite a bit for the straight Lycoming style. Used are running 100.00 and new around 160. If you want he angle adapters like from ECI they are close to 400 for the kit.
Jesse
970-874-7575
Old 01-03-2017, 01:04 PM
TnMike's Avatar
TnMike TnMike is offline
Default Oil Filter on RV4 Conical Mount
Casper labs couldn't get one to fit mine so like Dwight I went with a straight mount like this.
Using the small K&N filter leaves lots of working room in my RV4..
Thanks,Mike
Dues Paid
Old 01-03-2017, 03:14 PM
merlin3 merlin3 is offline
where are you finding oil filter adapters for the 0-320 for $100-150? I would like to switch to an oil filter but everyone i see is a ridiculous 3-400 for a piece of metal.
Justin
Rv-6, o360, whirlwind cs prop, old paint and panel
Rv-4,o-320,prince prop, mgl avionics screens - sold
Old 01-03-2017, 07:07 PM
Default ADAPTERS
I have several new and used. Call me tomorrow sometime and I'll hook you up!
Jesse
970-874-7575
Old 01-03-2017, 08:43 PM
Thanks, will do!
Justin
