I'm considering installing an Artex 345 in my RV 7A. Several have said the whip antenna on the 345 is nearly two feet tall. I measured my AK- 450 antenna and it is only 16 inches above the tail cone forward of the vertical stab.
Seems like two feet will require me to move it forward from the existing spot to make sure it doesn't touch the vertical stab at higher speeds. Has anyone installed this antenna in this area on an RV 7A?
LLL
LLL
