Capt_Riney
Member
Ever have one of those days on your project where you just throw down your tools and say "I'm done for the day". Had one yesterday. I'm working on a QB RV-7 kit trying to attach the A407 / A406 aileron brackets and keep gouging the holes in the end ribs of the ailerons. The pilot holes in the ailerons are about#30 and I need to drill them out to the final 3/16" size for the AN3 bolt. But every time I try to drill them, the drill bit grabs on the aileron spar, thrusts forward and bends/gouges the hole in the flange of the aileron tip rib. I've tried clamping everything tight with cleco clamps and starting with small size drill bits and working up to 3/16", but still having problems. When the drill bit grabs it's like the drill leaps out of my hand. The only other thing I can think of is to try to use my drill press so I can control the plunge of the drill bit.
Any ideas?
Any ideas?
