Old 07-05-2018, 11:20 PM
nilberg nilberg is offline
You're making good progress and it's looking good.
One tip: The torques seal is not supposed to be on the bolt. It's between the nut and a solid surface. See http://www.eaavideo.org/detail/video/29739769001
Bjorn N - RV 7 in progress
Katy, TX
http://www.mykitlog.com/N741BN
Old 07-06-2018, 08:43 AM
jcarne's Avatar
jcarne jcarne is offline
Thanks for the nice comment!
I disagree with this method on using torque seal. I think it is more important to know if the nut has rotated with respect to the bolt (theoretically if it's not on the threads the bolt could rotate and the nut remain stationary and you wouldn't know). If I have to remove a bolt with torque seal on it I am just going to replace it anyways.
Jereme Carne
PPL
RV-7A Emp. done
Wings mostly done
Working on Fuselage
Finish kit on order
Exempt but gladly paying!
Old 07-06-2018, 08:55 AM
wirejock's Avatar
wirejock wirejock is offline
Default Torque seal
Agreed
It should be a line from bolt to nut to surface. Anything turns and it's easily noticed.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 07-06-2018, 09:42 AM
Default Trying to say
I agree the torque strip should be from the surface onto the nut to the bolt. I think the video is mistaken in that the torque strip should not be on the “bolt” side of the fastener; but it definetly needs to indicate if the nut has turned on the bolt.
John S
Fuselage started
Old 07-07-2018, 10:47 AM
Steenos Steenos is offline
Incredible progress once again! Keep it going.
Air Traffic Controller FAA
Instrument Pilot
Old 07-07-2018, 07:54 PM
jcarne's Avatar
Thanks Steenos!
Jereme Carne
PPL
RV-7A Emp. done
Wings mostly done
Working on Fuselage
Finish kit on order
