Hello,
Section 11-9 figure 2
I am finally assembling the elevator trim bellcrank on my RV-10. I do not seem to have enough clearance to insert both AN960-416L thin washers on either side. I can fit one easily on and it rotates freely but the second one on the far side creates a tight fit and does not allow the bellcrank (F-1095B) arm to rotate freely. Can I remove the one thin .032 washer and not have any washer on one side or should I redo the F1095C brackets?
Or better yet, can I just substitute the NAS1149D0416H .016 think washer on both sides?
Thank You.
Thank You.
