  #31
Old 05-08-2019, 09:47 AM
Toddsanderson Toddsanderson is offline
Good points Tom,
I currently have a V35 with a IO-550. It is consistently a 166-170 knot plane on roughly 12 GPH at 11k ft. It's just getting long in the tooth. 50 year old systems just get tired. It has a nice triple Aspen Stack, but it just isn't the same as the new experimental stuff and the certified versions of the exp equipment is 5-10x as much money.
If I do buy another plane it will have fixed gear for sure and a modern panel. I'm not ready for retirement yet, but it makes sense to save money and have what you want before retiring.
I appreciate all the input.
Old 05-08-2019, 10:52 AM
bizpilot bizpilot is offline
Hi again Todd, we havenít had our 14A up to 12-14 thousand feet and done a fuel flow check. I did get 178 KTS TAS and 11 even on fuel flow on my trip south in March. This was at 9500 with a OAT of 6F.
We have 135 hours on the engine, it may do a little better when fully broke in.
Bob Bisbee
1/2 14A
Old 05-08-2019, 12:33 PM
Bob Bisbee
1/2 14A
Thanks Bob, that is a good reference. At 135 hours you are fully broken in.
Old 05-08-2019, 03:03 PM
Bavafa Bavafa is offline
If you need another reference point, my 14A does about 170k with 8.4G running LOP.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 05-08-2019, 04:08 PM
DHerzTX87 DHerzTX87 is offline
G36 Bonanza solves all your problems including your overflowing bank account.
Old 05-08-2019, 08:44 PM
That is really good fuel economy.
Old 05-08-2019, 08:45 PM
The G36 is not a good airplane, especially for the money. Low useful load, not very fast, and stuck with expensive avionics. I would keep my V35 and the extra $500k.
Old 05-09-2019, 12:10 PM
It was kind of tongue in cheek. Beech only builds about 10-15 a year at this point.
Old 05-09-2019, 01:43 PM
Yeah, I know. I have owned just about every Baron produced along with a couple of Duke's and Bonanzas. The new Beechcraft products do not excite me at all. I don't see the value.
Old 05-09-2019, 03:07 PM
Raymo's Avatar
Raymo Raymo is offline
No matter which you choose (sounds like the -14), give Lycon a call and talk to them about getting the most performance out of your engine without having to go turbo.
You might also consider working with SynergyAir for a build assist to get that new air plane smell in a relatively short time period.
Ray
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
All lines by TSFlightLines
