Old 05-06-2019, 11:04 AM
flybill7 flybill7 is offline
Default Riveting outboard bottom wing skin RV-10 QB
I'm helping a friend with his RV-10 QB. We are approaching the point of riveting the outboard bottom wing skin. The skin (and ribs) are all match-drilled, deburred, dimpled and edge-smoothed.
The plans/instructions don't really give advice on the best way to do this other than do the center of the skin first, then proceed outboard and inboard. Does anyone have a more specific guidance on how to rivet the outboard bottom wing skin on?
Bill Cloughley
Severna Park, Maryland
RV-7 Flying (1,400 hours)
Building Fokker DR-1 Triplane from Plans
http://www.pilotbill.com
Old 05-06-2019, 11:10 AM
bkervaski's Avatar
Find a small person with long arms to help. Patience. Be prepared for your arms looking like you might be a cutter. Patience. Watch the areas where the skin is pulled up so you don't make a smiley. Patience. Always cleco one more hole down than you are working to keep the skin flat for the rivet gun. Patience.
A wing stand is a big plus, we made one in about 30 minutes from some 2x4's, cost about $30. It only has to last through this phase.
If you have a kid helping they will learn a few new swear words that day
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
Old 05-06-2019, 06:10 PM
DRMA DRMA is offline
Roll the skin back and tie it with string through 1 or 2 of the outboard rivet holes. Then proceed one section at a time, working out and readjusting the string to lower the skin as each section is completed.
I tried it with the wing stretched across 2 work benches horizontally, and with the wing in a wing stand/cradle. I didn't find a lot of difference, but ended up preferring doing the work with the wing in a cradle with the leading edge pointed towards the floor.
Long arms do help, along with long sleeve shirts to provide some level of protection to the skin of the person bucking the rivets. Hopefully by this point you have practice bucking rivets strictly by feel, as that is what you will be doing for the most part. Take your time and you'll get it done.
Best of luck
Dave Macdonald
RV-10 Finishing Kit & FWF in-progress
2019 VAF Dues Paid
Old 05-06-2019, 09:20 PM
lr172 lr172 is offline
My instructions were pretty clear and different from this. It's been a few months, but I remember doing the inboard two sections from leadin to trailing edge (or vice versa), then the remaining ribs working outboard. Definately didn't start in middle and work out in two directions.
Lot's of scratches on the arms, but was able to do the whole thing myself witout trouble (save a couple of rivets) following the plans guidance.
N64LR
RV-10 in progress
