Old 05-04-2019, 07:12 AM
Blizzard Blizzard is offline
Default Ordering replacement pieces
Just a quick question about re-ordering parts. When you go to "the list" and order a replacement part like R-1015, is that generic to all rudder stiffeners? Can you always assume that the part number you are replacing is always the exact same from the list. Didn't know if there is a model number specific list?
Old 05-04-2019, 08:32 AM
The part number tells you which airplane it's for. For an RV-10, all the model-specific parts start with a 10. So there is only one List, and it has all the parts (or most of them, anyway) available for any airplane.
If you scroll around, you'll find parts for the RV-3 right on up. For example, C-302 is a welded aluminum frame for an RV-3.
Sometimes, parts are builder-fabricated from stock. In those cases they'll show the generic part number like AA3-032X3/4X3/4X4', which is a stiffener angle formed from .032 2024-T3. Chapter 5 explains the part numbering system.
RV-3B, now working on the top tailcone skin, the last fuselage skin.
Old 05-04-2019, 09:52 AM
Zuldarin's Avatar
Zuldarin Zuldarin is offline
Thats mostly true but there are parts from other models used on the RV-10 (and other models). So you could have a part number from an RV-6 on your RV-10 (rear seats come to mind). Just search for the part number called out for in the plans and it will fit. :-)
Darin
Snoqualmie WA
RV-9A Flying as of 03/2015
RV-10 Building - Fuselage
www.DarinAnderson.com
2019 donation sent!
Old 05-04-2019, 11:34 AM
Got it. It's what I assumed but wasn't sure. Thanks for the help.
