Old 05-15-2019, 05:24 PM
jacoby jacoby is offline
Default Elevator: blind or solid rivets?
Is it worth doing the solid rivets on the elevator? I bought the blind rivets. Does anyone have a compelling argument to use the solid instead? I figure they’ll look nearly identical with a bit of filler. Messing with the weird bucking bar looks like no fun at all.
Old 05-15-2019, 06:08 PM
Electrogunner Electrogunner is offline
Default Solid
I would go with the solid using the long bar. That bar will come in handy other places as well.
RV10 N620RV
IO540 C4B5
Whirlwind 375HRT
Garmin G900X
First Flight 2/14/2019
Old 05-15-2019, 06:16 PM
Brantel's Avatar
Brantel Brantel is online now
Solid was super easy with the special bar.
Brantel (Brian Chesteen),
Check out my RV-10 builder's BLOG
RV-10, #41942, N?????, Working on Emp/Tail Cone
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 05-15-2019, 06:39 PM
walker172 walker172 is offline
Yep. I did solid also. You can buy the bar from Cleaveland tool. That’s what I did.
Mike Walker
CF-18/F-16 Fighter Pilot
1st Time Builder - RV-10 #41779
Cold Lake, AB Canada
Old 05-15-2019, 08:50 PM
paul330 paul330 is offline
I'll go the other way - was very simple and quick to use the MK319BS.
In general, I found that I used more blind rivets as the build continued. There are some places where trying to set a solid rivet gets to be near impossible. My thinking was that the odd Cherry was better than a solid rivet that is either badly set or has been drilled out a couple of times.
Paul
Mercy Air, White River FAWV
RV-10 ZU-IIZ - "Zeus"
Building Bearhawk Bravo - RV-18 not available
2019 Donation Made
Old 05-15-2019, 09:30 PM
blucllrplt blucllrplt is online now
Used the solid rivets on mine with the long bar. End result was similar to the opposite side using a tungsten bar.
Old 05-16-2019, 06:33 AM
rongawer rongawer is offline
Default Going in blind...
I agree completely. Either rivet is physically capable of the job, so it just comes down to whether you want to buck it or pull it. And it’s a bad location for an “oops”.
Since you are contemplating, I recommend saving the money on the special bucking bar and do the blind rivet.
Ron Gawer
- RV10, N1530G (reserved). Build in progress.
- RV12, N975G, "The Commuter"
- Several others that are now just great memories for me.
Old 05-16-2019, 07:11 AM
The only downside is that that the MK319 is something like 30c a pop - no pun intended. On the other hand, if you are looking at $150-200k .......
Paul
2019 Donation Made
Old 05-16-2019, 07:25 AM
Yeah. I bought 60 of them at $0.30/ea. $18 isn't really going to affect the budget. Worst case I use them in other places.
I really don't want to have to drill any of those out. A local builder offered to let me borrow his special bucking bar. He also said the elevators were difficult (and I can see why).
It sounds like there really isn't a compelling argument either way. I need to pick a path and move on!
