The biggest problem I've had with the 9A is setting elevator trim before take-off, which I guess is no big problem, just annoying.
When landing, and on roll out, I give the trim handle a few small twists, and hope 2 things...1;, I hope I'm close on the next take-off, and 2; I remember to look at the trim tab and see if it's close to the right position before I get in the plane
It's no big deal to make the correction after rotation, but I hate the guessing.
I read a while ago about making colored grooves on the inner shaft of the trim rod so you can see where you are, but I've found that the trim is so sensitive, that is not good enough. I've found that there is less than 1 1/2 turns of motion of the knob to cover the whole flight envelope.
Has anyone come up with a form of a mechanical indicator that is neat and accurate.
The closest thing I can think of is some sort of a spring loaded arm that rests up against the trim knob, which moves in and out as you're making adjustments.
Jack
RV9A
52 hours
Just painted !!
Jack
RV9A
52 hours
Just painted !!
