Go Back   VAF Forums > Avionics / Interiors / Fiberglass > Electrical Systems
Old 01-15-2017, 04:05 AM
f1rocket's Avatar
f1rocket f1rocket is offline
Originally Posted by Eddie B View Post
PPS - Is it standard practice to log this change in the Engine or the Airframe logbook or both?
Typically, the airframe logbook. Remember that the JD regulator charges ar a higher rate than the Ducati so if you have a high voltage alarm limit set, you may need to bump that up a little. I did on my -12.
Glad you get your issue resolved. Keep us updated on how it goes over time.
Randy Pflanzer
Martinsville, IN (II87)
www.pflanzer-aviation.com
Paid through 2043!
Lund fishing Boat, 2017, GONE FISHING
RV-12 - Completed 2014, Sold
427 Shelby Cobra - Completed 2012, Sold
F1 EVO - partially completed, Sold
F1 Rocket - Completed 2005, Sold
RV-7A - Partially completed, Sold
RV-6 - Completed 2000, Sold
Long-EZ - Completed 1987, Sold
Old 01-19-2017, 07:04 AM
Fast Eddie B Fast Eddie B is offline
Got to the hangar and made a short flight yesterday.
Voltage readings (engine off):
Battery (Aerovoltz lithium iron) with Master Off: 13.25v
Battery with Master On: 13.11v
Garmin: 12.7v
Panel 12v outlet: 12.97v
Panel voltmeter: about 13.8v (a little parallax error in photo below)
Engine off:
Went flying, and with just the strobes and landing light on, saw the voltage gradually go from about 13.7v to 14v where it seemed to level off:
This is I think about .3v higher than the Ducati. Note the panel mounted voltmeter is consistently showing about 1v high.
I was a little surprised at the high resting voltage - I'm used to seeing about 12.7v on most lead-acid batteries. But the Aerovoltz data sheet says that higher voltage is typical, and the 14v charging rate is in the acceptable range:
Anyway, so far, so good. If anything changes, I'll report back.
Old 01-19-2017, 07:23 AM
BillL BillL is offline
Default Be advised . .
Ed, EarthX has documented an AC content limit of the charging power and the PM alternator/VR does NOT meet that specification.
You might do some research on that since you have a LiFeP battery. And/Or be sure your battery is in a sealed metal container with an external vent in case of a "thermal event" . AeroVoltz will not be special in this regard. Be safe up there.
Bill
1st Flight 1-27-18
Phase II 8-3-18
Repairman 11-15-18
Instrument Currency 12-17-18
Old 01-19-2017, 10:47 AM
Thanks, Bill.
Can you maybe provide a link to what the issues are?
Here's my installation in the nose of the plane:
(the photo is to remind me of the orientation of the terminals, which is opposite from stock)
I'm just using the bracket from the original lead-acid battery with a block below the Aerovoltz to take up the slack. Would not be too hard to fabricate a battery box to enclose it, if that was really necessary.
Just curious, do most builders/owners enclose their lithium-iron batteries? If so, is there a source for the enclosures or do you have to roll your own?
Old 09-21-2017, 08:10 AM
Thought I'd provide an update:
About 15 hours flown over the last 8 months or so.
The John Deere voltage regulator in my Sky Arrow has worked perfectly over that time frame, cranking out almost exactly 14v as indicated by my Garmin.
Thanks again for all the help, and yes - I definitely need to fly more!
Old 09-21-2017, 11:55 AM
tomkk's Avatar
tomkk tomkk is offline
What's the part number for the JD regulator you're using?
Tom
Port Orange, Fl
RV-12 N121TK ELSA #120845; first flight 06/10/2015
RV-12 N918EN ELSA #120995 Eagles Nest Project
SPA Panther N26TK in progress
Old 09-21-2017, 08:02 PM
My logbook entry specifies #330 322 332.
This is it on Amazon, from a search of my orders:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old 09-21-2017, 09:17 PM
Possible part numbers: AM101406, or MIA881279, or JDR1406
Joe Gores
RV-12 Flying
