zkvii
Hi,
The 2into1 Vetterman system I have on the 7A w/ IO-360 vertical carb has too much movement at the exit of the cowl. I've got the 'original' mid 2000's rubber hose with stainless pipe.
I understand there is a newer design which attaches to the lower mid engine frame bolts and uses a spring wrapped around the tail pipes. I've been search for some photos / details, and failing.... Anybody got details of the current design - any photos of installs?
Photos of your current designs? (KevinH / SamB et al)
PS: I know it has been a while between posts - been enjoying the flying too much
