Jackkclark
I had my share of removing rivets. Not my favorite task. So, to prevent making changes later to accommodate Sky View, at what point should I stop building per the original instructions and resume building with the new instructions that (I assume) will come with Skyview. In other words, should I continue and build the map box or stop at Page 29-6-1? Perhaps if I plan to have a single panel, the map box is still necessary?
Any other words of wisdom? Finishing Kit is on order. Tail cone not attached. Rear window not installed. Have not made changes to static lines yet.
