Getting ready to place an order with Spruce.
I'd like to go ahead and order my main battery lead.
I've mounted my battery box in the Vans recommended location, and I've also mounted my VP/X in the recommended spot (inverted between the middle and left rib just back of the firewall).
By my math 5 feet should be plenty of wire, so 8 gauge should be fine, right?
Also, what size firewall penetration are folks using for all the wires that need to go through the firewall on the right side?
I'm planning on bringing the engine monitoring wires through on the left side.
Will a 1/2 inch be enough or should I go with the 3/4?
-Dan
-Dan
