alpinelakespilot2000
Having just learned like many others that once a Plane Power fails out of warranty that they have no interest in fixing it (even at customer expense) but instead tell you that you need to buy a new one, I've decided to seriously consider going the automotive route. (Still investigating a local repair shop to fix the PP, but not too hopeful yet that I will be confident in it even if it does get fixed. And yes, I have thought about a B&C but not ready to spend that kind of $$ now.)
However, before I make the switch, I need to know what this brace between the starter and alternator is for. Since the starter is solidly connected to the engine case by four large bolts, the brace seems like its just along for the ride.
Will I need to account for the brace and connect it the different alternator mount bracket (Van's still apparently provides these for automotive style alternators) or can I safely leave it off without ill-effect to either the starter or alternator?
Thanks.
Thanks.
