Trim indicator HDX 1100 in RV 12
benfra
Member
Having a problem to get the trim indicator(elevator) to function. I have verified the 5volts from the 5000 distribution box to the (green 37 pin) D connector, so I have power. When I go to the screen to set the voltage to the indicator it shows no volts (upper RH corner) so I am probably missing some thing in the setup probably on another screen. Thanks for the help Ben
