Old 06-06-2018, 04:49 PM
SMO's Avatar
SMO SMO is offline
Sold 3 years ago
Mark Olson
1987 RV-4 Sold
2003 Super Decathlon - Sold
F1 EVO Rocket, first flight May 31/14
Old 06-06-2018, 05:37 PM
SmilingJack's Avatar
SmilingJack SmilingJack is offline
Originally Posted by SMO View Post
Sold 3 years ago
Me thinks Alan is in research mode for a price point
I see a new product coming.....
John Mastro
RV-8
Old 06-06-2018, 06:57 PM
Delta Bravo Delta Bravo is offline
I have the metal tube from Superior and used a "Real Gasket". First time I completely eliminated leaks thanks to the gasket material.
Don Bodnar
RV7A
Old 06-18-2018, 06:10 AM
swisseagle's Avatar
swisseagle swisseagle is offline
Be carefull when you safety-wire the tube. Due to the for and back motion when loosening an tightening the dip-stick, the safety wire at the tube to case connection, getts loose.
I safety wired mine in both directions, so thogether with the Real-Gasket is is absolutely dry now.
Dominik
RV-7A, TMX-IO-320, FM-150, Sensenich FP
Flying since 28. April 2016
Old 06-18-2018, 03:35 PM
N49ex N49ex is offline
Default Dipstick tube safety wire
I second the recommendation for the "Real" gasket - works wonders. But, don't forget it is 1/8th" thick, and Lyc gasket is near 0 thick, so your oil levels will be a bit high.
Re-the safety wire and tightening the dipstick - my local A&P taught me a number of years ago that folks way over tighten the dipstick, leading to some of the leakage and back and forth issue. It turns out that the upper o-ring seal does not require very much tightening - just very gently tighten - and it will hold just fine. Try it!
