Proseal on Rudder
findane
I'm getting ready to rivet the trailing edge of my RV9A rudder. I thought I read somewhere in the forum to run a bead of proseal on both sides of the center strip. Is this a good idea?
proseal on rudder
Yes, just don't get carried away. This is a flying surface which will require balancing before flight and again after it's painted. Also, some apply a very thin coating to stiffeners of the rudder prior to riveting. I didn't and have one instance of skin cracking along edge of stiffener.
As always, ymmv.
Proseal
As always, ymmv.
Agreed. Rough both surfaces with scotchbrite. Apply a thin coating to the surfaces and a dollop at each stiffener intersection. Cleko to a stiff, straight surface like a 2" aluminum angle. Leave it for a week then rivet.
Careful
Just don't assume that the proseal will make it invulnerable to careless riveting. You still need to set the rivets part way first, then set them all the way, checking for straightness the whole while.
