Swivel Mushroom Set Question
cczarnik
Question- I picked up a swivel mushroom set (a made in USA "good" one). Haven't used it, but noticed there is a lot of play in the ball / socket joint. I was expecting closer tolerances but have zero experience with this kind of set. Is this normal? TIA
If by "a lot of play" your mean the set loosely swivels around it's shaft (e.g. holding it upright the set easily falls to one side), then yes that's normal.
That sounds normal but FWIW, I started using one of those but soon learned that I did better riveting with less damage by using a solid flush set; in particular, the kind with the rubber washer/gasket around the diameter of the face. Good luck with your build.
Sounds normal.
I have the "loose" kind and the kind with a rubber "shroud" around it. Both are far better for riveting solo or with an inexperienced partner. It will want to slide around on you a bit and might leave some scuff marks but unless you're polishing you'll buff them out when you sand for paint.
Imagine that the socket is about 1/16" larger than the ball. Feels like you could make a mess in a hurry. I bought this for a backup for my standard mushroom but this will be a set of last resort. Haven't used it yet may change my mind after that. Thx all for the comments.
Best thing to do then is test it on some scrap. The nice thing about the swivel set is your technique doesn't have to be perfect to get perfect results.
Love my mushroom swivel set..
..and I use it for all my bucked flush riveting. Mine is more rigid than what you describe and I believe that a set that's more difficult to swivel is preferable. That being said, I wouldn't want to use a fixed set (i.e. no swivel). As far as it "marking up the skin during riveting," I put a piece of blue painter's tape on the metal surface part, to prevent this. You want the rubber sleeve to still be in contact with the airframe, to prevent the set from sliding around, but putting a little piece of tape in the middle will protect the aluminum. Depending on how high you set the air on your rivet gun, the tape should be good for about 10 - 20 rivets. Change it before it gets to banged up, or it takes longer to switch it out. I use a roll of 1" tape, which lasts a long, long time, and it's cheap. People always comment on how "scuff-free" my skins are. Then again, the painter will scuff them all up before painting, when the time comes. :eek:
Swivel set
Mine has a bit of play in the axial direction but it's build two planes and still works fine. I use tape too but I use heavy book tape on the skin, over the rivet. Usually good for quitd a few.
