I have an O-540-A1D5 engine for my RV-10. Yes, it has a carburetor. Since it doesn't require the high pressure fuel pump of a fuel injected engine, it also does not require the ES Airflow Fuel Filter. I have opted to install a simple gascolator on the firewall, but am having trouble finding a good place to mount it that will be the lowest point in the fuel system, easy to service, and clear of the engine mount. Has any one used a gascolator on an RV-10, and if so, where did you mount it?
