bruceh
Solved!
Bingo! I had selected the DIFF sensor definition. I changed that and did a run up and everything is back to the usual values.
Bruce,
Make sure you didn't select the differential selection on the fuel pressure sensor in sensor input mapping. There are two with the same part number one diff and one not.
