Old 02-13-2018, 02:40 PM
StuBob StuBob is offline
Originally Posted by ERushing View Post
Gil hit the nail on the head. That is a nutplate strip used to attach the rudder counterweight to the Rudder Tip Rib.
But not described in the manual????
Stu F.
Indianapolis (KMQJ)
Old 02-13-2018, 02:46 PM
ERushing's Avatar
ERushing ERushing is offline
The part is called out in the latest rudder drawing. The manual states "Install the E-614-020 counterweight (see exploded view on DWG 7).
Eric Rushing
VS, Rudder, HS, Elevator, Tailcone - Complete
QB Wings - Complete.
QB Fuse - In Process. Tail & Fuse are one.
Molalla, OR
Old 02-13-2018, 03:01 PM
Default Darn
Well darn, after 10 years I figured all the updates were done. Guess I am old style.
I wonder if it is worth reworking before paint?
John S
Dues paid 2019, worth every penny
Fuselage 30%
Old 02-13-2018, 08:10 PM
tyconnell tyconnell is offline
I may be blind, but I don't see that on the exploded drawing on my printed plans (kit ordered last summer). Nor do I see it on the PDF plans I ordered prior to that. No matter, if that's what it is, that area is already riveted together. I'm as certain as I can be that I put Loc-tite Blue Threadlocker* on those thinking, at the time, "I'm not getting to these any time soon."
Now the question is: how much of a safety concern is this?
*Aviation grade, of course ;-)
Ty Connell
Atlanta, GA
EAA Chapter 690
VAF dues paid monthly
ty.connell@gmail.com
N997TL reserved
RV-9(A?) empennage in progress
Old 02-13-2018, 10:19 PM
Default Me no worry
I am in the same boat. I am not going to worry about it. I figure there are 1000 rv 9s flying with my style of rudder. Just sonething to check every year during condition inspection.
John S
Fuselage 30%
Old 02-14-2018, 09:24 AM
wirejock's Avatar
wirejock wirejock is online now
Default Service Bulletin
If it were a safety issue, wouldn't Vans issue a Service Bulletin? So it must be a modification to the kit.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 12/27/2018. Plus a little extra.
Disclaimer
Old 02-14-2018, 09:07 PM
VA Maule VA Maule is online now
I don't think Blue Locktight as noted in post #14 will be of any benefit as the loosening of the lead is due to leads' ductility and or lack of resilience. I added some JB weld to the mating surface of mine.
Maule MXT-7(daily flyer)
Lancer 235(partner)
Raidial RV-8R Ephanage Done, Wings Done, Fuselage on it's tall Grove gear & engine hung
Old 02-15-2018, 03:49 AM
RV7ForMe RV7ForMe is offline
must be very new. I am positive I did not have this part in my 2017 -7 kit. The -9 Rudder happens to be the same as the -7...
VAF dues paid until 10/2019
RV7 (N137MX Reserved) - Empennage 95% done
RV7 (N137MX Reserved) - Wings Started...
RV7-A - Rebuild in process
Cessna Rocket 210HP - Best dang 172 Ever made! (sold)
Old 02-15-2018, 05:43 AM
BillL BillL is online now
Originally Posted by az_gila View Post
Check the hole spacing, it could be a "two nutplate holder" that replaces the two nuts retaining the rudder lead counterweight.
Weren't some folks having trouble with these nuts coming loose as the lead squished a bit and then had no access to tighten them after assembly?
This is my vote, the later lead weights a so soft that proper torque can not be attained on the bolts and stock washers.
You will have to fill the counterbore recesses, I machined an aluminum spacer for it, epoxy would work too. A standard washer is does not have enough surface area and will embed in the lead. I tested all of this. The lead mold is too cold and the lead is not hot enough when poured to make a good solid piece. Tested that too.
Vans just keeps getting better!!
I would.
Bill
1st Flight 1-27-18
Phase II 8-3-18
Repairman 11-15-18
Instrument Currency 12-17-18
Old 04-16-2018, 06:51 AM
TASEsq TASEsq is offline
Interesting..
Here’s a question I asked on the -14 forum, from following a build log, it showed the part and an install diagram from the 14 plans, but it was not shown on my preview plans nor on the plans changes section of the website. It shows the plans and part.
http://www.vansairforce.com/communit...d.php?t=159464
Do they ship kits with parts and plans not shown online? (I.e. plans changes online falling behind those sent out with kits?).
___________
Trent Stewart
Melbourne, Australia
http://www.tasrv14.blogspot.com.au/
Dues paid until April 2019
