Go Back   VAF Forums > RV Firewall Forward Section > Propellers
  #81
Old 12-10-2017, 09:54 AM
Uptown2k's Avatar
Uptown2k Uptown2k is offline
Looking forward to these results
Jordan
CFI/II
RV7 purchsed flying
Planning future build (RV-10)
VAF dues paid thru 06/2018
Old 01-22-2018, 07:45 AM
Uptown2k's Avatar
Default Any results???
Checking in to see if you had any numbers to share with us
Jordan
CFI/II
RV7 purchsed flying
Old 01-22-2018, 10:51 AM
Bob Martin's Avatar
Bob Martin Bob Martin is offline
Default Not yet
We have had some fitting issues, but getting them resolved.
Inital numbers are good/faster.
Main thing is 18 lbs lighter......prop and spinner combo.
Very pretty prop too...
I say this and it sounds hollow but it is true. A prop up until now has been a hunk of wood or metal with various paint jobs.
This prop has a finish that would rival the best paint job out there. Almost TOO pretty. One really has to be careful using powerful tools to torque nuts and safety wire etc around this prop.
Normally a prop just gets a cleaning or a wipe down, etc, but this prop begs for wax and to be taken care of.
Bob Martin
RV-6, 0-360 Hartzell C/S, Tip up, 1150+TT
James extended cowl/plenum, induction, -8VS and Rudder. TSFlightline hoses. Oregon Aero leather seats.
D100-KMD150-660-TT ADI2- AS air/oil seperator. Vetterman exhaust with turndown tips.
Louisa, Virginia KLKU N94TB
Old 02-10-2018, 08:58 PM
Northernliving Northernliving is offline
Default Performance?
Bob, any additional performance numbers on the prop?
Thanks, Brian
Brian J.
Boston, MA
RV8 Based at ORH - Purchased
RV8 - The Dream - Under Construction
Old 02-11-2018, 11:21 AM
gereed75 gereed75 is offline
Default Cg considerations
Bob, I am sure you have considered the effect on cg that this change will cause.
Several hundred hours ago, I switched from a 200rv to a hartzell Aluminum to gain 19 pounds on the nose. The cg moved from tending towards aft to right in the middle of the range. The flying characteristics are substantially improved. a 6 with aft range cg’s can be very sensitive in pitch, have tendencies to bounce landings and limits aft baggage in a meaningful way.
Hope you are not going there.
Gary Reed
RV-6 IO-360
WW 200 RV now an Al Hartzell for improved CG
Old 02-13-2018, 01:26 PM
Bob Martin's Avatar
Thanks, Brian
Brian,
No final numbers, preliminary numbers are good.
4mph faster at low cruise.
Time to climb to 8K was 6 seconds faster.
We had fitting issues with our James cowl and WW had us install a coarse stop ring in the hub. We are testing now for flight envelope. adjusting governor, etc. Once we are set, we will rerun the speed and time to climb tests.
Bob Martin
Old 02-13-2018, 01:33 PM
Bob Martin's Avatar
Gary,
Thanks for the input. I will look at the W&B, we have a recent one!
Our -6 went from a wood prop to a metal Sensenich to a C/S Hartzel to a James cowl conversion that included a 2.25 extension.
So we have gotten heavier and pushed the heavy prop farther out.
Taking 18 lbs off the nose seems like a wonderful thing.
It also made our wallet thinner.
Bob Martin
Old 02-13-2018, 10:09 PM
Hmm, interesting journey. I thought at one time that the extended James cowl with composite prop might be the optimal six configuration. Go for it and good luck!
Gary Reed
RV-6 IO-360
Old 11-20-2018, 09:01 PM
scrollF4's Avatar
scrollF4 scrollF4 is online now
Moderator, Asst. Line Boy
Default What about the cowling?
Originally Posted by ronschreck View Post
Hi Krea,
I don't have the engineering expertise of Steve Smith but I do have real-world experience with both props. I flew my RV-8 with a WW 200RV for about 1500 hours. I was given a Hartzell composite, wide blade prop when Hartzell sponsored our Team AeroDynamix.
Ron,
A friend of mine is contemplating the change from the WW to the Hartzell composite CS prop. When you made this conversion, how well did it fit with your existing cowling? Or did it require surgery on the cowling for fit?
Scroll
Sid "Scroll" Mayeux, Col, USAF (ret)
52F Aero Valley Airport, Roanoke TX (home of DR's Van Cave)
"KELLI GIRL" N260KM RV-7A tipper, YIO-360M1B with Danny King “Beautiful Doll’s” old Hartzell CS prop, dual PMAGs, dual SkyView, GTN-650, VPX, EarthX LiFePO.
Wrap by AircraftWraps.Com. Nose Art by VictoryGirl.com. Smoke by Smoke System Helper.
90% done, 90% to go...
www.mykitlog.com/scrollf4/
Proud and grateful 2019 -=VAF=- Contributor
Old 11-21-2018, 04:52 AM
ronschreck's Avatar
ronschreck ronschreck is offline
Originally Posted by scrollF4 View Post
Ron,
When we first mounted the props there were several that hit the cowling at high pitch so we sent them all back to Hartzell and they gave us props with a hub that put the blades and inch further forward. No clearance issues with the new hub and that is the hub that is currently provided. No surgery required.
Ron Schreck
IAC Director and National Judge
RV-8, "Miss Izzy", 2200+ RV Hours
Track Me *** Gold Hill Airpark (NC25)
VAF 2019 Donor
"Flying is the art of throwing yourself at the ground and missing."
