Routing Exhaust system
Bavafa
Just wondering if anyone had difficulties installing the tail pipe in a 14A model? How do you route the EX-0006?
I can get it in place from the left side of the gear leg but that puts it in reverse position, the hanger side will end up on the pilot side. It looks like it needs to be routed thru the right side of the gear leg but I will either need to remove the gear leg or the fuel fitting as it will not pass thru with these items in place.
Any tips would be appreciate it.
See if this helps:
http://rv-14a.blogspot.com/2017/02/fwf-exhaust-placed.html
You may need to move the U-01416 Nose Gear Link Assembly out of your way.
