They are probably pretty good lights, but they seem to be very large. Four and a half inches square. Where would you put them?
John
John - not sure which light you're looking at, but the Squadron lights are the ones Mike (bullojm1) chose. I have followed in his footsteps. These are good lights and are quite a bit smaller than 4.5" square. I've pasted the specs below. For those who want to be able to fry insects and small critters at night with the beam of their landing lights, this same physical package is now available in a 9000 lumen rating. Ok, not cheap, but that's a huge amount of light. The Squadron Pro's at 4300 lumens are plenty.
Specs for the Squadron Pro series of lights from bajadesigns.com website:
Specifications:
Lumens: 4,300 Utilizing 4 Cree XM-L2 LEDs
Wattage/Amps: 42W / 3.5A
Dimensions: 3.07" x 2.77" x 3.07"
Weight: 12 ounces
LED Life Expectancy: 49,930 Hours
Front Lens: Hard Coated Polycarbonate
Housing: Hard Anodized & Powder Coated Cast Aluminum
Bezel: Billet Machined Aluminum
Hardware & Bracket Material: Stainless Steel
Exceeds MIL-STD810G (Mil-Spec Testing)
Built-In Overvoltage Protection
IP69K (Waterproof, Submersible to 9ft)
IK10 Compliant (Mechanical Impact Testing)
