Go Back   VAF Forums > Model Specific > Rocket
Old 12-05-2019, 10:50 AM
smokyray's Avatar
smokyray smokyray is offline
Default Long Legs
Originally Posted by F1 Rocket View Post
When I originally built my rocket I made an aluminum tab on the bottom of each gear leg fairing that I then clamped to the lower gear leg with a hose clamp. These tabs have broken, allowing the gear leg fairing to “float” vertically. The upper/lower intersection fairings hold the alignment very well. I’ve flown this way for many hours but now that I’m getting closer to returning the airplane to flying status I’m wondering if I should leave the gear leg fairings floating or make some new tabs.
Hey Danny,
My HR2's original fairings were home made and full of stress cracks from landing on my rough turf home strip and eventually rendered combat ineffective.
I contacted F1 Boss Mark and he sent me a set of Team Rocket fairings that I installed in the "float" mode using my wheel pant and upper leg fairings to hold in place. My upper leg fairings have a slot at the back to allow even more fore aft movement.
End game: No cracks.
V/R
Smokey
Old 12-13-2019, 08:26 PM
RDOne RDOne is offline
Nice looking rocket Smokey. How does well does the naca vent in that location work? Trying to decide on how to vent mine now.
Old 12-14-2019, 07:18 PM
vfrazier's Avatar
vfrazier vfrazier is offline
Thread drift.... sorry.
On my Rocket, the side NACA fuselage air was consistently 11F hotter than the air coming from under the wing to the back seat. My RV-4 was similarly hotter. I don't recommend the side NACA scoops.
However, getting the air from under the wing to the front is a challenge due to the spar being in the way.
YMMV!
Vince Frazier
www.f1aircraft.com
F1 Rocket and F4 Raider components
www.flyboyaccessories.com
RV and Rocket Accessories, Tailwheels, Tools, & More
1-888-8FLYBOY (1-888-835-9269)
F4 Raider - under construction
F1-H Rocket "Crazy Horse" - sold
RV-4 "Chief Pontiac" - sold in 1994, purchased in 2018
Old 12-16-2019, 11:03 AM
I-TERA's Avatar
I-TERA I-TERA is offline
Danny,
my answer to the same questions:
I suspended the fairing with a rubber belt at the engine mount, closed the fairing with a hinge and ,to avoid vibrations, installed on the leg ,with double side adesive band , some foam.
Two openings in the leading edge of the wing root fairings conducts air ( a lot of fresh air ) behind the instrument panel and in direction of the pilot without interfering with the spar.
Pics : https://www.dropbox.com/sh/49ialxn7q...QGuvddEca?dl=0
Claudio
Claudio Ricci
F1 Rocket EVO
Old 12-21-2019, 05:58 PM
F1 Rocket F1 Rocket is offline
Originally Posted by I-TERA View Post
Danny,
Claudio
Nice installation. Do you have any photos detailing how your upper fairing attach fitting works?
Danny
F1 Rocket #25
N14ZM "Dreamer"
Melboring, FL
Old 12-22-2019, 05:19 PM
I-TERA's Avatar
Hi Danny,
pics added in the folder " gear leg remake ". A big hole in a grass taxiway....and a new gear leg ( titanium spring bended, pant destroyed, no other damages).
Claudio
Claudio Ricci
F1 Rocket EVO
Old 12-23-2019, 01:19 PM
Thanks I may be able to do something similar.
Danny
F1 Rocket #25
N14ZM "Dreamer"
Melboring, FL
