Old 06-18-2018, 07:18 PM
Ron B. Ron B. is offline
Default ADSB call
I was lazy and did not address calling Dynon about the update required for the 472 ADSB. Got a call from Dynon this afternoon asking if I had heard about the required update and that they are sending me out a new updated unit tomorrow and for me to return my unit to them when I receive the new one. I thought this was good service.
Thanks Dynon
Thanks Ron
RV-10 SOLD
RV-14 Flying
Old 06-18-2018, 09:28 PM
Jpm757 Jpm757 is offline
Received mine about 2 weeks ago and it's working great. If you're using the Skyview Network be sure to do a hardware scan to update the network. I failed to do this on my next flight and got some configuration flags on my ADS-B performance report.
Jake
RV6 completed 1991 sold.
RV7 #72018 N767T first flight 11/21/2017 170+ hrs.
IO-360M1B MT 3 blade, Dual AFS 5600.
1941 J3 Cub skis floats.
2019 dues gladly paid.
Old 06-20-2018, 11:12 AM
Jesse's Avatar
Jesse Jesse is offline
The ads-b box doesnít connect to the sv network. There should be nothing needed to be done in settings when swapping the units.
352-427-0285
jesse@saintaviation.com
Old 06-20-2018, 12:35 PM
Raymo's Avatar
Raymo Raymo is online now
You may need to update the 472 to the latest software after installation. The process is similar to the transponder.
Ray
O-360-A4M w/ AFP FM-150 FI, 1 PMag, Vetterman Trombone Exh, SkyTech starter, PlanePower Alt
All lines by TSFlightLines
NSDQ
Old 06-20-2018, 01:24 PM
RViter RViter is offline
Thanks Dynon
Enquiring minds want to know ... when did you 'apply for the -472 upgrade'? (i.e., how long have you waited?)
I know this is a thread high-jacking, but I'm looking anxiously for that Dynon call as I see Osh2018 approaching ...
(thanks for your post - a ray of light in the darkness)
gary
RV-6A QB Tip-Up, 1st Flight 3/18/17
O-360-J2A (modified & F/I), Sensenich FP (cruise)
VP-X Sport, Dynon SkyView, VFR day
(FFZ) Mesa, AZ - N234GB -
www.mykitlog.com/garyc
Old 06-20-2018, 01:44 PM
MercFE MercFE is offline
Got mine as well... Looks like they're just going through the list and slowly contacting each person with the older box. I did nothing to start the exchange process, they called me.
Old 06-20-2018, 01:48 PM
219PB 219PB is offline
I called about mine and got put on their list. Still have not heard from them.
Paul Bonorden
RV-6A under construction
My Builders Website
Victoria, TX
2019 Dues Gladly Paid
Old 06-20-2018, 03:04 PM
I already had the upgraded 472 , just needed the updated version. And no I had not contacted them about update, they called me.
Thanks Ron
RV-10 SOLD
RV-14 Flying
Old 06-22-2018, 11:29 PM
DrillBit's Avatar
DrillBit DrillBit is offline
Got my Dynon-initiated call today. Revised 472 is on its way. Including the 470 that I had to begin with, thatís 3 ADSB-in receivers before 1st flight.
Kurt Haller
P-town, CA (10 min from KLVK!)
N748PK, RV-9A
Airworthy as of 21 January 2019
VAF dues last paid 9 Dec 2018
Old 06-23-2018, 01:57 AM
Mark C. Mark C. is offline
Have any of you guys make a mounting bracket for the 472 as it uses screw location from the 470? Dynon said I would get a call early Fall for mine.
Thanks, Mark C. IL
