Old 06-14-2018, 09:44 AM
bullojm1's Avatar
bullojm1 bullojm1 is offline
Hi Michael,
After I installed the flange around the intake tube, I placed the O-ring in first, and then the retaining metal ring on top of the o-ring. I then pushed down on the metal ring to make it flush with the top of the flange and o-ring.
This made installation pretty easy, as it all wanted to stay together.
Mike Bullock
RV-7, Flying!
http://www.rvplane.com
EAA Technical Counselor
Old 06-14-2018, 10:02 AM
Toobuilder's Avatar
Copy all. If you don't mind doing an experiment, try installing the O ring on the inner retainer first, then set it aside. Install the two bolts to hang the tube (big gap), then slip the O ring assembly in and draw the bolts up. Please report back with relative observations.
I have a set on order for the Rocket so it will be a while before I can try "your" method to compare.
Michael Robinson
______________
RV-8 - Flying
Old 06-14-2018, 05:18 PM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
I use Mike's method as well, O-ring installed over inner ring, put bolts in a few threads, drop the O-ring and inner ring into the recess while holding the tube down, do up the bolts.
There is an arc cut into the face of the silver ring to aid in keeping the O-ring in place.
Good thing is once you get the bolts tight, you should never have to touch this stuff again.
BTW, we shipped out a bunch more today and some more will go out tomorrow to those who ordered and paid.
Another CNC run is scheduled for June 27th.
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, RV6A C-GVZX flying from CYBW since 2003- 426.1 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://sdsefi.com/cpi.htm
Old 06-18-2018, 03:50 PM
bullojm1's Avatar
Michael - I tried your method, but I couldn't assure that the inner metal retained ring wouldn't slip out. The only way I could assure all of the parts were oriented correctly was by using my original method.
I did run into a frustrating situation on my #1 cylinder where the flange would want to slide down the intake tube while trying to get my screws aligned, causing the o-ring and metal ring to fall out. This was quickly remedied by using some electrical tape to hold the flange as high as possible during assembly.
I finished installing everything on Friday and went up for a test flight. Without exaggeration, THIS IS THE SMOOTHEST MY ENGINE HAS EVER RAN! I have always struggled running LOP - typically I could get down to about 10 degrees LOP (7.5 GPH at 24 squared), but any less than that and the engine would let me know. Friday I was able to go down to 6.9GPH and the engine was quite happy with me on my 0.7 hour test flight. I went for a 2.4 hour flight yesterday and experienced the same smoothness and ability to run lean.
Thanks for a great product Ross! It's the single best upgrade I've made to my RV.
Mike Bullock
RV-7, Flying!
Old 06-22-2018, 08:58 PM
grubbat's Avatar
grubbat grubbat is offline
Default Great Product
Installed mine on M1B tubes. Had to chop them then reweld. All I can say is that this is a great product. Engines runs great after being plagued with induction leaks from poor custom made tubes. Thanks Ross!!
Craig
RV-3 Sold
RV-4 Sold
RV-6a Sold
RV-9 IO-360 CS, Built and Flying
Comanche 260 - poor mans RV-10
Old 06-27-2018, 01:35 PM
rv6ejguy's Avatar
I'm glad that people are seeing some good benefits with these and actual running improvements. I'd just hoped to end the maintenance headaches always replacing gaskets.
A large batch of CNC'd flanges and rings will be completed today and will be going to anodizing tomorrow.
Thanks to all the folks who've PM'd and emailed me to place their orders.
I was not able to order the 1.75 CT clamps for the carbed engine induction hoses due to the high minimum order requirement so at this time, we can only supply these CT clamps for injected engines. I'll try to find a more agreeable source for these. In the meantime, people can use their existing clamps. I do have a large supply of Superior 1.75 hoses now for carbed engines.
I'd expect anodizing to be done early to mid next week and we can start shipping then.
I'll be contacting people shortly for payment and shipping addresses.
Old 06-27-2018, 03:33 PM
Mike S Mike S is online now
Originally Posted by rv6ejguy View Post
I
So, no take the $$$ up front and ship whenever???
Good on you Ross
Old 06-27-2018, 03:38 PM
Raymo's Avatar
Raymo Raymo is offline
I'm now on the list too, with plans to incorporate them into a Superior cold air sump upgrade this fall.
Ray
O-360-A4M w/ AFP FM-150 FI, 1 PMag, Vetterman Trombone Exh, SkyTech starter, PlanePower Alt
All lines by TSFlightLines
NSDQ
Old 06-27-2018, 04:05 PM
rv6ejguy's Avatar
Good on you Ross
For non-custom parts, we usually wait until we have the parts in hand before charging credit cards.
For CPIs and EFI kits and custom etched valve covers, we'll charge cards when we are about to commence working on them and try to ship pretty quickly after that, subject to supplier and our work backlogs.
We've heard that some other vendors take money 30-120 days before delivering any parts. We don't feel that's a fair way to do business.
Old 07-05-2018, 04:13 PM
rv6ejguy's Avatar
Default Flanges in hand
Ok gents, I picked up the flanges from the anodizer this afternoon so can start shipping tomorrow. I'll contact those on the list first who've spoken for a set.
Thank you to everyone for your support and being patient.
