If I recall correctly, those use the old PCMCIA cards. You should be able to find something on Amazon that will work with those cards.
Here is one from a quick search:
https://www.amazon.com/Addonics-AEPUDDU-Pocket-Ultra-DigiDrive/dp/B00006L318/
I've not used that one in particular so can't guarantee that it will work, but that's the general thing you are looking for, I believe.
-Dj
Hi Gary, are you interested in selling your Progamer and data card? Thanks Mike
Questions on the GX60.
2. For the life of me I can't seem to find GPS approaches on my GX60. Is there some sort of lockout if the database isn't current or the unit's software is out of date? I "think" I've gone through every possible menu during some cross countries and for the life of me I can't find the approaches. Any help is greatly appreciated!
From page 6-22 of the GX60IFRGPS_COMM_UserGuide.pdf
Load Approach (GX50/60)
This option is available for the Active flight plan when a datacard with approach information is inserted into the GX50/60. Press ENTER to show the available approaches for the desired airport. Press SEL while in the NAV or Map function to go directly to this option.
On my GX60 with 2-year old database, I can load an approach 50 NM out for the airport that I am navigating to as long as there is an approach for that airport.
