Old 11-21-2019, 07:38 PM
rocketman1988 rocketman1988 is offline
Default Thanks!
I did not note the Canada location but I thought it might be educational to post the FAA section as I had the same question...
I am not planning on a whiskey compass...unless the DAR requires it...
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
297 HP Barrett Hung
ShowPlanes Cowl with Skybolts Fitted - Beautiful
Wiring...
Dues Paid 2018,...Thanks DR+
Old 11-21-2019, 07:47 PM
noelf noelf is offline
Did a walk through on a Gulfstream G 550. There is no wet compass. What they do have is a solid state separate compass that is independent of the rest of the glass displays.
Noel
RV-6A N6NF
tip-up
flying
Old 11-22-2019, 08:51 AM
Snowflake's Avatar
The wording in the CARs:
Power-driven Aircraft — Day VFR
605.14 No person shall conduct a take-off in a power-driven aircraft for the purpose of day VFR flight unless it is equipped with
(d) a magnetic compass or a magnetic direction indicator that operates independently of the aircraft electrical generating system;
I have a Dynon D10A with internal backup battery. In the event of a failure of the generating system, it still operates, therefore it is independent of the aircraft electrical generating system. Ergo, I have no wet compass.
Rob Prior
Old 11-22-2019, 10:04 AM
Ron B. Ron B. is offline
What about a Skyview along with it's back up battery ?
Thanks Ron
RV-10 SOLD
RV-14 Flying
Old 11-22-2019, 10:15 AM
Mousse Mousse is offline
Your should be OK. You meet CAR 605.14(d). MDRA inspector would not accept this on my -9 but after consulting with TC, he had no choice to accept it. MDRA cannot be more restrictive than the CARs.
Michel
Exempted but dues paid through 12/2020
RV-9 Sold
RV-10 Flying
Old 11-22-2019, 01:41 PM
Wish I would have known this. Thanks.
Thanks Ron
RV-10 SOLD
RV-14 Flying
Old 11-22-2019, 02:20 PM
kmbusse kmbusse is offline
Thanks for that
Old 11-22-2019, 03:58 PM
Jpm757 Jpm757 is offline
There are a variety of compass apps available for download to your phone. They are quite accurate, would be useful in a pinch.
Jake
RV6 #20477 completed 1991 sold.
RV7 #72018 N767T first flight 11/21/2017 250+ hrs.
IO-360M1B MT 3 blade, Dual AFS 5600 QUICK Panel.
Manual Flaps. KOXC Oxford, CT
1941 J3 Cub skis,floats.
2019 dues gladly paid.
Old 11-23-2019, 11:01 AM
Snowflake's Avatar
Further info on this... The MD-RA site now has a PDF outlining compass requirements, that doesn't outright say that you can't use an EFIS instead of a whiskey ball.
http://www.md-ra.com/docs/C70E.pdf
(this is on the "Articles of Interest" page, bottom of the first section)
Where the regulations still fall behind with the times is that even though you have an EFIS-based compass, that once calibrated doesn't have deviations, you still need a compass deviation card.
At least, once I calibrated my D10A, I could put my nose on any axis of the compass rose and the reading was +/- 1-2 degrees, which was certainly no less accurate than my placement on the compass rose.
Rob Prior
