Old 12-07-2019, 03:49 PM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
Originally Posted by gmcjetpilot View Post
Does ND (Japan) actually make them or do they outsource it out to the same folks making the clones? Who knows. VW's are made in Mexico and Honda's are made in Tennessee. A
Denso can't afford substandard parts quality to save a few pennies by offshoring components. I'd guess that any plant they set up outside Japan would be supervised by Japanese and employ the same process control and QC as is used in Japan.
You don't risk a 50 year reputation as the top OEM auto supplier of electrical components in the world. We've seen how that turned out for one supplier here...
I have a friend who works at Denso in Japan, I'll ask and see what he can find out.
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, Shorai- RV6A C-GVZX flying from CYBW since 2003- 436.1 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://sdsefi.com/cpi2.htm
Old 01-14-2020, 01:27 PM
Wayne Gillispie Wayne Gillispie is offline
Default Second PP 60 amp alternator failure on RV-10
First one that came with the kit failed at 191 hrs. Voltage down to 12.8 from 14.2 VDC. Whining over intercom below 1200 rpm. The STATOR was not secured properly with epoxy coating, hot glue or sealant. No star washers were used under screws. This caused the the stator wires to break down deep, which are unrepairable. Replaced stator for $80. Keeping this alternator for a spare. Prop was balanced (PP liked to blame all of their broken stator wires on vibration or heat), no #1 exhaust heat shield and no cooling blast tube used since new. No problem with rectifier, regulator, oval 3-pin connector or brushes. No signs of overheating.
Second one has now failed at 45 hrs. Voltage down from 14.2 to 13.6 VDC. I will let you know what I find on that one. Time for a change and I won’t be spending $600-$800 anymore on $100-$150 alternators. 3 pin oval connector replaced as part of my troubleshooting. No change. Replaced 9 year old PC925L just in case. No change. Replaced 3 yr old, 3rd PC680 aux battery. No change.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Old 01-14-2020, 03:39 PM
BillL BillL is offline
Originally Posted by Wayne Gillispie View Post
First one that came with kit failed at 191 hrs. Diodes. Second one has failed at 45 hrs. Time for a change.
I hope you are holding Hartzell's feet to the fire for help on that early hour failure. Like an overnight shipment, teardown report, and labor to install the new one. Levi ( I think is his name) came on here and helped us at one time understand their improvements.
Do you know what failed? Did you use the new connector, or the old one?
Bill
1st Flight 1-27-18
Phase II 8-3-18
Repairman 11-15-18
Instrument Currency 12-17-18
Shrunken Exit = ??
No Photo? => PM me.
Old 01-17-2020, 07:45 AM
Default 2nd PP voltage decreasing
See my edit above. I will keep you guys informed.
There is nothing special about these overpriced alternators with their “proprietary” overvoltage protection. How many overvoltage occurrences have you heard of in automobiles or aircraft. It’s just a way to charge $500 more to us “rich” airboat owners.
I am not calling Hartzell. It is poor business practices and customer service to sell an alternator, then not provide repair parts or repair services at a minimum. Instead, they just recommend buying a new one. I trust my local guy with 50 years of experience.
Old 01-17-2020, 12:08 PM
azrv6's Avatar
azrv6 azrv6 is offline
My Duralast 14184 finally quit last month after 24 years and 1000 hours of faithful service.
Dave Binkley
RV-6, O-360-A1A, C/S
1932 Monocoupe 110, Warner 145 (http://gobinkley.com)
Sedona, AZ
Old 01-17-2020, 07:18 PM
Sam Buchanan's Avatar
been here awhile
If you still own the 1978 Honda Civic you can go get a free replacement alternator.......
Sam Buchanan
1999 RV-6
1918 Fokker D.VII replica
