Old 05-10-2018, 10:42 AM
Raymo's Avatar
Raymo Raymo is offline
Looks like Jepp sells them but it does not list the GX60 in the compatibility list. Might want to give them a call.
https://jeppdirect.jeppesen.com/main...=prod850002_ca
Ray
O-360-A4M w/ Catto 3 blade NLE, AFP FM-150 FI, 1 PMag, Vetterman Trombone Exh, SkyTech starter,
PlanePower Alt, FlightLines Interior, James cowl & plenum
All lines by TSFlightLines
NSDQ
Old 05-10-2018, 11:45 AM
RV6_flyer's Avatar
Originally Posted by JonGruber85 View Post
Questions on the GX60.
2. For the life of me I can't seem to find GPS approaches on my GX60. Is there some sort of lockout if the database isn't current or the unit's software is out of date? I "think" I've gone through every possible menu during some cross countries and for the life of me I can't find the approaches. Any help is greatly appreciated!
From page 6-22 of the GX60IFRGPS_COMM_UserGuide.pdf
Load Approach (GX50/60)
This option is available for the Active flight plan when a datacard with approach information is inserted into the GX50/60. Press ENTER to show the available approaches for the desired airport. Press SEL while in the NAV or Map function to go directly to this option.
On my GX60 with 2-year old database, I can load an approach 50 NM out for the airport that I am navigating to as long as there is an approach for that airport.
Gary A. Sobek
NC25 RV-6
Flying
3,300+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 05-10-2018, 12:15 PM
JonGruber85 JonGruber85 is offline
So I tried that and came up with nothing. That is what is causing me so much grief. I have a database that I updated 2 months ago so near current. And I was flying into KCMI which has GPS approaches. Pressing SEL got me nothing. I tried other menus and couldn't find it either. I may call jeppesen to make sure the database that I got included gps approaches. Could that be my problem?
Old 05-29-2018, 02:29 PM
mv_myrx mv_myrx is offline
Default GX updates
Data base updates ARE available the subscription is $450 per year it serves the GX50,55,60,65 If your looking for a 1 time update contact me and I can help.
Old 05-29-2018, 02:32 PM
IF you have never used this GPS for approaches before it may not be setup for them. I have 2 apollos a 50 and a 60 that I installed myself so I have had to learn a lot of the setup. If I can help let me know
