Old 09-24-2018, 02:05 AM
Snap Snap is offline
Default Retrofit Roll Bar RV-3
Hello Enthusiasts!
is there any possibility to retrofit a roll bar to the RV-3? Unfortunately our RV doesn't have one and we fly from more or less "good" grass strips only.
Wasn't able to find it in the Vans shop either.
Thanks guys!
Simon
Simon
"Nothing is more powerful than an idea whose time has come." (Victor Hugo)
Old 09-24-2018, 08:14 AM
Ironflight's Avatar
VAF Moderator / Line Boy
There are two drawings for roll bars in the RV-3 plans if I recall - and I have seen many other designs by various other builders. Take a look at the plans and they may give you some ideas. It will be somewhat invasive.
Van’s never offered any parts for them.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 09-24-2018, 11:07 AM
Drawing 37 shows a sheet-metal one and SK-54A shows a welded steel tube one.
Old 09-24-2018, 09:00 PM
FinnFlyer FinnFlyer is offline
You should be able to cut holes in the top back skin behind the seat back bulkhead (same principle as cutting flap actuator holes) and feed the two steel tubes through them and then weld them together at the top (U-shaped top steel piece) as per SK-54A. You'll probably need a 3/16" angle drill to drill the attach holes in the longerons.
Finn
Old 09-27-2018, 01:14 PM
Thank you guys for the Input, that's what I needed to know!
I prefer the steel tube method for looks and roundabout visibility.
Simon
Old 09-27-2018, 06:37 PM
MiserBird's Avatar
MiserBird MiserBird is offline
Default RV-3 roll bar detail
The roll bar installation in my 1980 RV-3 looks pretty robust with no holes in the skin:
Dave McKinnon
KAJR - Cornelia, GA
1975 Cardinal RG N1593H since Mar 1993
1980 RV-3 N3VR Bought flying Sept 2017
2018, 2019 VAF Dues Paid
Last edited by MiserBird : 09-27-2018 at 06:54 PM. Reason: Trying to insert picture
