Old 07-18-2018, 03:04 PM
RV7A Flyer's Avatar
RV7A Flyer RV7A Flyer is offline
What's the advantage of putting in two reservoirs on the cylinders, instead of one reservoir on the firewall?
Maybe I just don't understand the big win here...
2019 Dues paid!
Old 07-18-2018, 03:53 PM
aturner's Avatar
aturner aturner is offline
I have pedal mounted reservoirs, and like them. They are very easy to check and service. I have a -10, which may have more room and easier access to the footwell than other models. ? I prefer the pedal mounted reservoirs because it eliminates a couple of hoses and connections. Nice and simple.
-Andy Turner
RV-10 N784JC
Old 07-18-2018, 04:09 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Plumbing that isnít there canít leak.....
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 07-18-2018, 05:44 PM
Scott_F Scott_F is offline
Originally Posted by Ironflight View Post
Hmmmm. I must be doing it wrong then. I have pedal mounted reservoirs on all four of our airplanes, and never have to do anything at the reservoirs. I have the sintered bras caps to allow air in and out, and pump brake fluid up from teh bottom. Air exits through the sintered caps. Never end up with any spilled fluid, never have to crawl down to the reservoirs - easy.:
Paul -it was your description of this method on another thread that swayed me to go this way.... and this: https://youtu.be/bZlq87VXybU
Thanks for the help.
Scott Fechtig
Patuxent River, MD
RV-7 - Finish Kit
Old 07-18-2018, 06:30 PM
Okay, I'll ask the question:
How do you check fluid level without crawling down there to peek in?
I've got the brake-mounted ones on my Cessna, and it's a real pain. And there are large doors near there, too, to make it easier.
Dave
Old 07-18-2018, 07:03 PM
JonJay's Avatar
JonJay JonJay is offline
I only find it necessary to check fluid levels once a year, at time of CI. You should be down there anyway lubing up rudder pedal and brake hinge points, checking rudder cable, weldment, etc..... I use a short length of clear tubing, stick it in and put a finger over the top of the tube. I pull the tube up just far enough to gauge the level of fluid, then let it go back into the reservoir.
I take issue with the EAA video. If you fill the reservoir, pedal mounted or FWF, it will overflow a small amount for quite some time. Sticky mess. That mess just drips down the firewall, but obviously it drips on your interior if your pedal mounted.
I fill only 1/2-2/3 full. That allows for expansion.
Six of one..... add this to the never ending debate. I have both types of systems and can't say either is better or worse, just different. The FW mounted reservoir with Vans plastic lines does allow you to see if the resevior has run out. You will see a bubble in the incoming line before it affects your brakes.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 07-18-2018, 08:54 PM
drakerv drakerv is offline
Default brake
Same as Paul. No problems after 10 years. Marc. RV8A
Old 07-19-2018, 05:51 AM
RONSIM's Avatar
RONSIM RONSIM is offline
Default On the Cessna,
They were a pain --- to check fluid levels, to top off, everything bad. Cannot imagine how I could do it on my RVs.
Ron
RV-10 Co-built, maintained, flown (sold)
RV-8A Maintained and flown (Sold)
RV-6A Bought and Flying (N177RV), upgrades $$$
IO360, 180HP/CS, AFS 5600T, D10A, G650, G430, G327, ADS-B, VIZ385 AP
Very Happy Contributor
Comm, SMEL, CFII, A&P
Based at KCLW (Clearwater, FL)
Old 07-19-2018, 06:28 AM
Scott Hersha Scott Hersha is offline
I have the individual reservoirs on my RV8, had them on the last RV8 also, and they are very easy to service/check with the baggage floor removed as others have said. You can service through the 1/8 vented pipe plug, or just unscrew the cap (thereís an O-ring seal) and the top is wide open. Easy to bleed or add fluid without spilling any. Definitely more difficult on a side by side. If you use the firewall mounted reservoir, I would recommend something other than the plastic compression fittings that come with the kit, because they usually eventually leak. I ended up changing mine on my RV6 to the Safe-Aire push fittings like you use on your plastic pitot static lines. They held up fine and didnít leak - and this is just for the non-pressurized clear plastic feed lines.
SH
RV6/2001 built/sold 2005
RV8 Fastback/2008 built/sold 2015
RV4/bought 2016/sold/2017
RV8/2018 built/Flying
Cincinnati, OH/KHAO
JAN2019
Old 07-19-2018, 09:34 AM
JonJay's Avatar
750 hours 11 years, per plans from Vanís. No leaks, ever. They will not leak when properly installed. I believe Vanís demo fleet will speak better than I.
However, for some reason, people just donít get how they go together. Safe-air are much more fool proof, not saying anybody is a fool.
Bucker Jungmann
RV1 - Proud Pilot.
