What Brand is this caliper
BH1166
1991 RV6a not built by me, but wanting to get some spare parts, o rings, pads etc but cannot determine the brand of caliper. I see in the log that pads used in past were Matco PN WHLM 66-106 and rotors/disk Cleveland PN 164-01700. Here is what the caliper looks liike. Thanks...Butch
[/IMG]
Probably Cleveland. But if it turns out not, given its vintage and sand cast appearance, it might be a Cleveland clone made by Fred Rosenhan way back in the day.
Fred was better known for the inside-caliper brakes later made by Matco, but I've heard he once dabbled in Cleveland-pattern outside-caliper brakes.
Vans part# BRAKE PAD KIT 5:00x5 sells (or used to) are Matco kit WHLBRL-1
which have the 66-106 pads in it & are pretty common.
Caliper o-ring should be MS28775-218. I haven't ran into a 5" wheel caliper that this doesn't fit yet.
I once replaced a rotor with a Rapco replacement part & if I remember right, I had to shim the caliper as the rotor was a smidge thicker than the original.
