See if the seller has the original log book and paperwork. It will be there.
Roller lifters were an option for Superior and should be indicated by the Model designation on the data plate. All the model number breakdowns should be on Superior's web site.
I have the roller lifters on my engine. I could have looked it all up for you, but all my manuals just got boxed up an moved while we are doing some house remodeling.
That vintage of superior engine with rollers lifters will have adjustable screws with lock nuts and safety wire installed top of lifter bore inboard of the pushrod tubes.
That is it. The hardware and safety wire on the crankcase above where the pushrods enter the case is the way that you tell on the Superior Crankcases.
If your serial number ends in "E" its is a roller lifter model.
