can someone provide guidance? Write ups, links anything?
Here's what I do - plug or cap all openings, exhaust ports, etc. be sure to use gaskets on the exhaust port and carburetor openings Drain all old oil preferably hot right after you have run it is best. Remove top and bottom spark plugs. Spray the cylinders through both the top and bottom spark plug holes with LPS 3 or preservative oil. Install the bottom spark plugs and dehydrator plugs in the top spark plug holes. Go to WalMart and buy 4 gallons of cheap oil and fill the engine all the way up. Check the desiccant and recharge every few months. Come back in 12 years drain everything, uncap everything, remove the spark plugs and wash the cylinders and engine down with solvent, spray a bit of LPS2 in the cylinders, add new oil and spark plugs and fire that baby right up.
If you open it up it will look just like it did the day you put it away.
Wow, I hope so. I noticed in the Lycoming bulletin, it lists an active and an inactive engine. For the inactive engine, it says to run the engine until operating temp is reached. After my Engine is built how does one normally run it without the airplane?
If you build the engine, and do not run it prior to preservation/storage, then it will not have and corrosive combustion by products or moisture in the oil.
If you buy a new engine it will have been dyno run then run again after adding preservative oil that will coat the internal surfaces of the engine.
So if you have a new crate motor from the factory, what would be the recommended pickling procedure for a couple of years storage (beyond what they do at Lycoming)?
My Plan:
I just secured my IO540, so I want to send everything out piece by piece and basically have everything ready for assembly in 13+/- months. However still freshly machined parts would still rust, right?
Absolutely will. Still needs some protection.
A quick look turned up 1481B, which stated lycoming ships from factory, engines warranted for 60 or 180 days of storage, and marks the package. (Won't swear it is latest and active)
That is my recollection from when I got my engine a few years ago.
Don't assume factory fresh means leave untouched, uninspected, in a corner for a few years. ...But better have preservative, oil and dessicant when you open it up.
