Old 04-02-2018, 01:29 PM
BillL BillL is offline
Originally Posted by Mark Dickens View Post
I just take my hand drill and very carefully drill a #40 pilot hole on one side. Then put it in the jig and drill it through to the other side with the drill press. It's always worked for me.
Yep, and look through the end to visually align through the center, the curve will do the rest.
It is the location on the opposite side that makes it a diametrical hole.
Bill
1st Flight 1-27-18
Phase II 8-3-18
Repairman 11-15-18
Instrument Currency 12-17-18
Old 04-02-2018, 01:46 PM
Default gave up on rivets
I gave up on the rivets and welded mine. For my 9, the rivets touched the rear spar at the extreme ends of travel and I didn't like that. YMMV
John S
Dues paid 2019, worth every penny
Fuselage 30%
Old 04-02-2018, 01:54 PM
Pixair Pixair is offline
Default Drilling hole in round tube
Might try a "center drill" into punch mark to get hole started. Or I often use a small end cutting end mill instead of drill bit.
Set up will need to be as rigid as possible for the milling cutter and with a slow feed rate into material. Not something you can "hand hold."
A milling machine is preferred, but small end cutters will work in a drill press as long as there isn't much play in the spindle.
Can probably get the above bits at a local machine tool supply store (if you have one in your area) or Amazon or MSC on line.
Old 04-02-2018, 02:09 PM
nilberg nilberg is offline
I would use this: https://youtu.be/n7HLfHZlKL4
Instead of clamping, firmly duck tape the v guide to the tube and use a hand drill. I used that on the tip-up release mechanism tubes and those are even smaller diameter than the aileron push rids. .
Bjorn N - RV 7 in progress
Katy, TX
http://www.mykitlog.com/N741BN
Old 04-02-2018, 02:55 PM
bkervaski's Avatar
I got them done by carefully drilling a tiny pilot hole with a hand drill and then using the drill press to finish. The fully drilled through pilot hole was enough to keep everything on track.
I like the welding idea lol
Progress: Flying!
Old 04-02-2018, 03:38 PM
9GT's Avatar
9GT 9GT is offline
Center drills work wonders for stuff like this. And don't buy the cheap China crappy ones!
David C.
Howell, MI
"Donor Exempt" but donated through Dec. 2019
Old 04-02-2018, 04:42 PM
Taltruda Taltruda is offline
Default Holes on tube
I have had luck drilling holes on tube by filing a flat into it first, then center punch the flat, and drill. Just keep the flat area smaller then the hole so that when you upsize the hole, the flat disappears.
Tom
Las Vegas
RV-8 empenage started
Baby Lakes flying
Old 04-02-2018, 10:23 PM
sf3543 sf3543 is offline
If you are still having trouble drilling those i have two suggestions you can try
Make sure the v block is in exactly the right place by putting the drill bit down all the way to verify it is touching the center of the v to insure it is perpendicular.
Also, You can make a saddle out of a piece of scrap tubing with a drilled hole in it. Place the saddle on the tube with the hole over the spot you want to drill and it will keep your bit from wandering. You can clamp the saddle on or make it big enough to just hold it in place till you get the bit started
Steve Formhals
RV6, RV8 (2), RV12 & RV3 99% done.
A&P, Tech Counselor & Flight Advisor
Old 04-03-2018, 07:02 AM
DanH's Avatar
DanH DanH is offline
Make a tool...
Dan Horton
RV-8 SS
Barrett IO-390
Old 04-03-2018, 08:22 AM
bkervaski's Avatar
I got mine drilled using a pilot hole instead of a punch .. but keep the suggestions coming this is all great stuff!!!
Progress: Flying!
