What type of abrasives are compatible with Aluminum?
Danny7
I'm trying to find some polishing/ deburring attachments, and i remember some note about avoiding certain abrasives.
the 3m cut and polish wheels come in both aluminum oxide and silicon dioxide, is one better than the other?
regarding sandpaper or wet/dry paper, i've found both ao and sd, also garnet.
anything special to look out for?
is it safe to use the polishing compound in the dremel tool package?
edit- I know to not use steel based abrasives such as steel wool. probably copper as well.
Danny,
I'm not sure about the specific abrasives you asked about. But a piece of general advice about deburring: where possible, use cutting tools rather than abrasives to deburr aluminum. Deburr holes with a countersink bit, deburr straight edges and outside curves with a mill file, and inside curves with a round or half-round file or any number of commonly available specialty tools. Where you still need to use abrasives to smooth out an edge even more, scotch-brite abrasives work well and have no compatibility problems with aluminum.
I have no experience and no advice to give on polishing aluminum, but there have been quite a few threads on the subject. I'm assuming from your question that you intend to have a polished aluminum finish on your airplane. Otherwise, if you plan to paint it, then polishing is not necessary.
Danny,
can you tell me more about these?
i'm looking at one in particular:
http://www.widgetsupply.com/page/WS/PROD/dremel-polish/BEN93
it says it is aluminum oxide based. Is that ok?
it looks like avery and probably everyone else sell this:
http://www.averytools.com/p-76-6-scotchbrite-cutting-and-polishing-wheel.aspx
which if is this:
http://solutions.3m.com/wps/portal/...GLE0_nid=GS8S8T4BQ8gsH55CPWS904glN9XV9L9H84bl
must mean aluminum oxide is ok, because that is what 3M says it is based on.
so AO is ok?
alum polish
Get a Scotch Bright wheel for your grinder. It's a necessity, and provides all the polishing you'll need. A vixen file for edges and you're set. Never use black sand paper (anything with carbon in it will promote corrosion). For roughing in parts a 1" belt sander works great.
I have the scotch brite wheel, i have files.
thanks for pointing out the black sandpaper, i used that some, but followed it up with scotch brite hand pads.
I was in general looking for guidelines on specific abrasive used such as silicon carbide, aluminum oxide, garnet, etc.
the particular tool i wanted to buy was a lot like the scotch brite wheel, maybe a bit looser in density, but about 1/4 in diameter. i figured it would work really well in corners of ribs. someone once told me to get a similar tool, but through sears. i was trying to buy something over over the internet, not at a sears store.
Aluminum Oxide
Use aluminum oxide products.
Do not use silicon-based products, garnet sandpaper, etc. as these contaminate the aluminum. [EDIT: I checked my source again and garnet is allowed by AC 43.13-1b]
I used the Scotchbrite wheels and (one roll each grit) of aluminum oxide emery cloth from leevalley.com (listed as 'abrasive rolls for turners'). Norton 3x sandpaper is also aluminum oxide and should be available locally.
Mike
Danny,
Avery also has the 1" and 2" wheel and mandrels for use in die grinders or cordless drills. Comes in handy when deburring the inside of holes, like lightening holes. I also found a tiny (1/2" dia?) deburring wheel of the same material for the dremel. Then there are the maroon and grey scotchbright pads available in the paint section of any decent hardware store.
If you are going to get deburring wheels from another source be aware that there are different consistencies. The 3M scotchbright 7A wheel that Avery sells for the bench grinder and die grinders is tough and is for "cut & polish". There are softer grades that break down faster for straight polishing. They look the same but are spongy to the touch.
John Tierney
Salem, WI
This has been discussed before...
Mike
...and the conclusion is that Silicon Carbide is OK for aluminum.
Check out the post from Bob Avery here...
http://www.vansairforce.com/community/showthread.php?t=19870&highlight=silicon+carbide&page=3
This NASA document also says it's OK....
http://corrosion.ksc.nasa.gov/pubs/tm584c.pdf
...and if NASA says it's OK for spacecraft, it's probably OK on our RVs....:D
NASA Wins
As always, I learn a lot on these forums. Hadn't seen the NASA paper before; when I stocked my shop last year I based my shop supplies on what I read in AC 43.13-1B.
Table 6.1 shows silicon carbide as OK for ferrous metals and titanium...and the row for "aluminum alloys other than clad aluminum" specifically says "do not use silicon carbide abrasive."
Based on this table, aluminum oxide is good for everything, while silicon carbide and garnet have only limited uses in corrosion removal. I've edited my earlier post to delete the reference to garnet, since it's allowed in the table for aluminum.
NASA research seems like a better source...maybe the FAA and NASA can get together on their research!
Mike
Ceramic Abrasives?
Pardon my ignorance.... I have searched for ceramic abrasives in these archives and found none. Anyone have any idea if they can be used on our little toys?
TIA,
Mike
Regardless of the media type, the biggest issue with sanding, grinding, or cutting aluminum is the ability for the material to clear. Aluminum is soft and melts at a low temperature. It will clog up and bind if the wrong material, grit, or matrix is used.
Scotch Brite is effective because the aggregate is bound in a polymer or plastic matrix. The aggregate is adhered to threads of plastic. This allows the aluminum to release free, along with some aggregate, plastic, and adhesive. You always have a clean pad, disk, or whatever to a point. You know it?s done when it appears loaded with material, or it is no longer a useable size.
Sand paper works fine but may clog and the thin layer of aggregate doesn?t last long.
The only fast rule is avoid anything that could impregnate the aluminum and leave traces of material like iron. Also, the typical grinding wheel is bad as the aluminum will clog up the wheel and generate high enough temps to melt and leave a deposit. The ?myth? is that the wheel will fracture and blow up, but I have seen some pretty loaded up grinding wheels that dressed up just fine after an unknowing person used them.
