Go Back   VAF Forums > Model Specific > RV-4
Old 01-25-2019, 10:19 AM
Larry DeCamp's Avatar
Larry DeCamp Larry DeCamp is offline
Default Sam James Cowl problem..Need suggestions
The cowl for the -4 is supposed to be for 0320 0r 360. My wide deck Superior 0360 really fits tight at at the rocker covers. However, it gets worse.
The cheeks are not symmetrical and require extreme force to get it to conform at the firewall/top longeron intersection on one side only, while the front of the cowl is level and conforms nicely to the spinner back-plate.
Sam says you can use a heat gun to get some compliance at the firewall. longeron junction, but that exacerbates the rocker cover interference.
Advice?
1- Don't be bashful with the heat, just make it happen ??
2- Start cutting and splicing to make things fit ?
3- Just buy another cowl, maybe F4 carbon or ?
4-What else can you think of ???
Larry DeCamp
RV-3B flying w/ carb / Pmags / Catto 2b / Steam
RV-4 fastback w/ Superior XP360/AFP/G3X/CPI/Catto3b
Clinton, IN
Old 01-25-2019, 04:21 PM
Ralph Inkster Ralph Inkster is offline
Ross used some old cylinders & covers I have laying around when he was developing his line of SDS valve covers. We found that the Superior valve covers were slightly deeper & corner shapes not as rounded as compared to other Lycoming covers due to the rocker shaft bosses shape being a different shape. Unfortunately trying to use Lycoming covers won’t work on your engine for this reason.
I think the cut & splice or cut out & fashion new cheeks may be the option I would pick, to create at least 1/2” clearance all around. Never had any luck when trying to warp things to fit.
Ralph
Maintain lots, upgraded - repaired - & modified more, rebuild a few, & built some too.
Old 01-25-2019, 04:37 PM
9GT's Avatar
9GT 9GT is offline
A heat gun can work sometimes and be very careful not to burn the composite. I would just cut and re-glass as needed. It really is not that difficult to do.
David C.
Howell, MI
RV-9A: Under Construction.
RV-10: Completed 12/29/2013 SOLD 08/23/2016
"Donor Exempt" but donated through Dec. 2019
Old 01-25-2019, 05:07 PM
Kyle Boatright Kyle Boatright is online now
I'd cut off the outer portion of the cheeks, reposition them outboard, and re-glass. DanH could do it in an afternoon. It'd take me a month of evenings.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 01-25-2019, 06:36 PM
Default Thanks guys 🤙
I had drawn the cut and conform conclusion while awaiting your input. Just fyi for others, the heat gun casused a clear delamination of glass/ resin evidenced by silver appearance of glass fiber. So, plastic surgery next, no problem...build on..thanks !
Larry DeCamp
Clinton, IN
Old 01-25-2019, 08:20 PM
AX-O's Avatar
AX-O AX-O is offline
I had to cut mine to pieces. I should have pics of what i did on my photo albums. I also had to make new cheeks because the profiles did not match the cowl.
Axel
RV-4 fastback thread and Pics
VAF 2019 paid VAF 704
The information that I post is just that; information and my own personal experiences. You need to weight out the pros and cons and make up your own mind/decisions. The pictures posted may not show the final stage or configuration. Build at your own risk.
Old 01-26-2019, 05:30 AM
Default Thanks AX-O
I dont even have cheek extentions cause many posts implied they dont fit anyway. I am thinking the best way to form the lip inder the cowl is to mold the cone to match the cowl with wooded former under the rear edge, then bond a strip of glass or carbon to hold the skybolts. I know Randy L. used al strip, but I think glass to glass bonding will be better for me.
Comments welcome.
Larry DeCamp
Clinton, IN
