Old 01-14-2019, 08:26 AM
texdog texdog is offline
Question Ads-B in
I have a GRT SPORT SX and GRT Sport HS. No WAAS approved GPS, but a Garmin 696 is mounted in the panel. Which screen should I put ADS-B in to?
T82 Fredericksburg,Tx.
Don't make easy hard!
Aircraft
RV6A owner
L19 sold
Dues paid 2015,16,17
Old 01-14-2019, 08:32 AM
330drvr 330drvr is offline
Assuming you have an 232 from your ADS B IN, split it and connect to both.
Bruce Brock
N174MR
RV-7A
IO-360
Dual GRT HX & Mini
Dual Adaptive AHARS
GNS 480 Navigator
Dues paid 2018
Old 01-14-2019, 08:33 AM
Skid's Avatar
Skid Skid is offline
Default ADS-B in
Which one do you use as a primary display? Do you have any hi speed ports available in both displays? GRT Fly-Safe requires a hi speed port for the connection, not sure what other use.
Skid
RV-6A
IO-360 B1B
Old 01-14-2019, 08:36 AM
Snowflake's Avatar
Depends on your ADS-B in device. A Stratux will feed the GRT display, I understand, but it won't feed the Garmin.
Rob Prior
Old 01-14-2019, 12:22 PM
Also depends on your panel. IMHO weather can go almost anywhere, but traffic is best if itís displayed right in front of you (main PFD).
