PTT Switch Sticking-Fix?
mbauer
On my last flight the PTT switch is sticking.
Anybody have this issue? How did you fix it?
Best regards,
Mike Bauer
Same here.
The springs in them get bad a lot. I would get another good brand one and just change it out. Your call. Yours. R.E.A. III # 80888
Ray Allen G205 Grip
After searching the web, looks like I have a Ray Allen G205 grip.
After reading the advice, anybody know which switch from Aircraft Spruce is a direct replacement for the PTT SPDT.
http://www.aircraftspruce.com/catalog/elpages/edmomomentary2.php?clickkey=3008651
or
http://www.aircraftspruce.com/catalog/elpages/edmomomentary6.php?recfer=5745
Bought my Rv as already flying, don't have any paperwork or instructions on how to replace, anybody have the instructions? Did not find any on the Ray Allen site.
Best regards,
Mike Bauer
Wanted to fly today, clear skies and 20deg F. Decided to try a little spritz of remington gun dry lube. It worked fine.
Thought about using some silicone spray, research said, "not good for electrical contacts or plastic/foam rubber".
Made sure to spray the dry lube at a 90 deg side angle and not force any into the switch. Was able to fly without the PTT sticking.
Now planning to buy a complete new switch and replace, for now the temp fix is working.
Best regards,
Mike Bauer
