AN Bolt Markings
SantosDumont
I'm inventorying the hardware in my RV14 empennage kit. I'm confused by the multiple markings on these AN3-6A bolts.
Are these actually all the same bolt?
14Vi8IJKq2iLhbacqdarGDrr9y3AgvodzjElm7tB5Q_NSzQusgD8BgXoA-dpvmt5V7Rd7ifrFW_Jicx-4CuYt6V62q3RTcy136H2wUIL4zWyPxBkrNDKgGc2USJYV-eZ7HxSkLxrYnFm74H5wliBZsNOuPaoNrEK93y41AeS9GohM3izkVjvsIHXTankiq1VhBnCh05GSixXOvc6-igrZK6MyeI0jbotKGh-rSNclZ9884A2W5QqTrh56D7xYv8viFCDwjBZHbwqIhujxABwY14VsZ0VS7IPo9WnCqlucD0zfvuRZNe11dEukQZoS9h9vpUoqsIhHvJ4QN5JsPVVEH1KGRALjnLFmIYsvHuV0yF22EUGyWn8o-9gWLLKfSolmlbWXSXZ6XO1fQqKETBtN3Dn7H4CmV9-udq4OHCouJU1rcONiDNzQpSfFEMZP49Ud-eLWDhNPoBzZ8E2XsWCEWEfmNiRJmne8QuWIvrsFJaqqv-oy56A0AOcvOiQkd9L_ZtT8VwN58yYzLSywPDpo9VV_qwNtAIsMI2pfwTe9DPeidTo3_fl0uTJivKgaDhmd6FYB6Ae2EJ-8pXEGyy5ucpJGTFqFA3a_kogZf5JEaj9eQJz_VctUg9W6Zui-Dysq2PcvbAF3imfek1x_9G3b9zKBLJ6m0aaUZNhWqnc0WzTqTSaLgJUBn_P=s1241-no
If you don't already have one, suggest you pick up a copy of AC 43.13-1B / 2A,
provides answers to everything... than some.
Mil-Spec
If that's not annoying, try and figure out Mil-Spec part numbers. What are they smoking?
Thanks.
I couldn't find a reference in AC 43.13-1B that said what the X meant.
7-36. IDENTIFICATION.
Aircraft bolts may be identified by code markings on the bolt heads. These markings generally denote the material of which the bolt is made, whether the bolt is a standard AN-type or a special-purpose bolt, and sometimes include the manufacturer.
a. AN standard steel bolts are marked with either a raised dash or asterisk, corrosion resistant steel is marked by a single dash, and AN aluminum-alloy bolts are marked with two
raised dashes.
teaching trick
I've stolen from others:
Get an Aircraft Spruce print catalogue to keep on the shelf with your AC43.13 -- has pics of many/ most typical hardware. Easiest method to parse the leftover bags of randomness....
General Aircraft Hardware use to send out a reference book. It is a great resource as well.
