Go Back   VAF Forums > Main > Reviews
Old 10-10-2017, 01:29 PM
mr.sun mr.sun is offline
Default WiFi in metal hangar building
Any tech guys out in VAF world that speak I.T. well enough to help me choose equipment well enough for getting WiFi to a group of metal hangars? There is hardwired internet at an airport maintenance building elevated about 1000' feet from my hangar which happens to be the furthest away. It is line of sight from my hangar roof and I don't mind putting up some sort of small antenna. I think I can get other hangar owners to chip in on this project. I'd sure like to use WiFi to pre-heat my engine and check weather and file flight plans online. Recommendations?
Greg RV-7 flyer
Donated Again
Old 10-10-2017, 01:49 PM
greghughespdx greghughespdx is offline
I can use Alexa either in person or remotely (via app) to turn stuff on and off using an electrical outlet similar to Bruce's (I have an Amazon Spot in the hangar - which also makes for great Pandora streaming!)
Van's Aircraft - Media and Community Director
Van's web site | Instagram | Facebook
Opinions, information and comments posted by me on this site are my own unless I specifically state otherwise. They do not represent direction from or opinions of my employer.
Building RV-8A since September 2014 (N88VX reserved)
VAF build thread - Flickr project photo album - Project Facebook page
Flying spam can, helped build and fly a few RV-12s and some other RVs
Hillsboro, Oregon (EAA 105)
Old 10-10-2017, 02:19 PM
Raymo's Avatar
Raymo Raymo is offline
Greg,
I was a network engineer prior to being a software engineer and just set this kind of thing up at my hangar - sending WiFi about 300 ft from FBO. Cost was about $125 for equipment.
2x Ubiquiti NanoStation loco M2 and associated mounts (1 Window suction cup and 1 wall/pipe mount).. Also need CAT 5/6 wire and an access point. You could go first to a switch and run wires to adjacent hangars for their access points.
If you have clear line of site, you could use the 5GHz model (slightly more expensive).
Send me a PM or email and we can talk it through.
Ray
O-360-A4M w/ AFP FM-150 FI, 1 PMag, Vetterman Trombone Exh, SkyTech starter, PlanePower Alt
All lines by TSFlightLines
NSDQ
Old 03-11-2018, 09:16 PM
BruceEicher's Avatar
BruceEicher BruceEicher is offline
Default System Update
03-11-18 Update. The Wemo worked for a season or so, but after a firmware update (I suspect) it stopped playing well with the Verizon Hotspot.
So I purchased an iHome switch and a multi monitor for motion, temperature, sound, light and humidity. A push notification tells me what’s going on in the hangar. It and the switch is working well with the Verizon box.
Bruce, Katie, Hana and RV-8 HulaGirl
Old 03-11-2018, 09:31 PM
RV8JD's Avatar
RV8JD RV8JD is offline
Bruce,
I copied your system awhile back and it worked well. Then, like you, the WEMO stopped talking to the Verizon Hotspot. I tried all the standard fixes on the Belkin Forum to no avail, and was about to give up. Then I saw an old Belkin note that had as the very last suggestion to change the router's bandwidth from 40 MHz to 20 MHz. I was able to do that to the Verizon Hotspot, and Voila, it has worked flawlessly since!
Which iHome switch and multi-monitor did you get?
Carl N.
Arlington, WA (KAWO)
RV-8, 405 Tach Hours
(Pic 1),(Pic 2)
(Pic)
Glasflügel Standard Libelle 201B, N564NS - Sold
Old 03-11-2018, 10:06 PM
Hi Carl,
Good work finding a solution! I’ll keep that in-mind if I find further problems. I now have the Isp8 switch and Iss50 sensor. The wemo might be used at home.
Thanks!
Old 03-12-2018, 04:03 AM
Piper J3 Piper J3 is online now
I use a 4G-GSM-High-Amperage-Remote-Control-Relay https://www.ebay.com/itm/4G-GSM-High...o/192083520963 to operate my engine preheater.
T-Mobile has a 30 text/month stand-alone cell phone data plan for $3.00/month.
Unit reports back to my cell phone that relay is on for x amount of time. To verify, I have an electric analog alarm clock on same circuit as heater. I reset hands on the clock to 12:00 and when I get to the hanger I look at the clock and see that the heater has run for set time.
Works great...
Hinckley, Ohio
EAA #499867
PPL/ASEL 1970 - Sport Pilot since 2004
RV-12 E-LSA #120058 AWC Jul 2012 - Bought Flying Oct 2015 with 48TT - Hobbs now 402
LSRM-A Certificate 2016
Special Thanks to EJ Trucks
Old 03-12-2018, 06:42 PM
Plummit's Avatar
Plummit Plummit is offline
What are you using to power the GSM box? The link you posted shows a DC voltage powered box.
-Marc
N814RV
2018 Donation made!
Old 03-12-2018, 07:00 PM
-Marc
Something like this... https://www.ebay.com/itm/12V-2A-Powe...UAAOSwT6pVySGN
Hinckley, Ohio
EAA #499867
Old 03-16-2018, 08:00 AM
R7237 R7237 is offline
Default Hub Install
I think instead of WeMo hardware, I would just install a SmartThings hub. You can get them off amazon for $49 on occasion and gives you a WHOLE lot more options for accessories. Security, Lights, Compressor Switches, Power Monitoring etc etc. It also will run most of the devices "local" so if you loose your hotspot, you can still control things, just not remotely. Just my 2 cents worth. Makes wiring hangar light a lot easier and cheaper with just a relay at the light as opposed to running everything to a light switch.
