I had no success with the masking tape method of measuring the tangent line of the canopy to the front bow. I ended up running black electrical tape across the bow and using a silver sharpie to make the tick marks every 2". I made them as a little cross. Then, with the canopy on, the canopy contact line made a shiny line on the black tape. On the cowling I marked whether rmy target was right on or whether it needed to be drilled 1/16" forward or back, etc.
Questions:
Is there supposed to be a rivet in the center 2" where the weld is?
We have to redrill every hole , from #40 to #30, or from #30 to #27. Is there a less risky alternative? Burning holes makes stress, and I don't have a #27 unibit.
Why not drill #30 and #27 holes in the first place?
Further on, you are supposed to drill the rollbar, etc #30 and tap for #8 screws. Won't this break the tap?
John
Questions:
John
