Aircraft Specialty
Not sure if anyone has come across this, or if this is just something that exists in every kit and should be ignored, riveted and not worried about.
I am at the step where you put the tailcone bottom skins on sawhorses and cleco the bulkheads to them.
The picture here shows the F-1208 bulkhead frame where it clecos into the two bottom skins of the tailcone. In the boxed area, you will notice that the flange of the bulkhead sort of overlaps one of the skins, rather than fitting nicely into the cutout. It would require more than just filing, but rather significant removal of material to enlarge that cutout in the skin and make room for the flange to nest in there. I don't know why that cutout wasn't enlarged as 2 out of the three bulkheads have this overlap and the third has a cutout where the bulkhead nestles perfectly in.
My gut reaction is to just leave it and rivet it together. The hole is far enough from the edge that everything should suck up fairly tight in there.
Anyone else at this stage of contruction that can take a peek at their tailcone?
Thanks so much
Steve
Thanks so much
Steve
