Old 08-21-2019, 07:51 PM
Saber25's Avatar
Saber25 Saber25 is offline
Default Can you measure up or down ?
Today I was visiting with an RV-9A builder as he was ready to find the angle of incidence on his project. Does the measurement 4-5/64" ring a bell ? It's the measurement for determining rear spar height from a horizontal plane which sets the angle of incidence for the main wing. Wow, 5/64th is a figure I had never worked with. It gave me a whole new appreciation for builders of the new generation of RV's.
I couldn't get it out of my mind so unfurled my -4 plans 1150, published in 1981, and searched for what was then the generally accepted measurement of the day. It seems Van's at the time favored 1/8 or generally the smallest was some version of the /16th. I did find a 13-11/32 and 13-27/32 on page 13 of my plans concerning the center bulkhead wing carrying structure. Van kept measurements pretty simple and quite effective throughout those plans so what happened?
I'm pretty sure I would have made that 5/64 into a 2/32 or better yet, 4- 1/16 and call it a day. I think I had it pretty easy back in the day.
Cheers, Hans
Build 'em light, keep it simple
I'd rather fly than tinker.
"There's a big difference between a pilot and an aviator. One is a technician, the other is an artist in love with flight."
- Elrey B. Jeppesen,
Old 08-21-2019, 08:32 PM
N941WR's Avatar
N941WR N941WR is offline
So many times in the plans they would give you a dimension to the 64th of an inch and when you would fit the part you could be off by a 1/4". That drove me nuts!
However, when setting the incident on the wings, you can bet I was as close as possible!
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 08-21-2019, 08:43 PM
TX7A TX7A is online now
Default I remember...
...seeing measurements like that “sprinkled” throughout my build. I figured it was yet another way to meet the 51% rule by annoying the builder.
Or, in actuality, maybe they were measurements derived through CAD drawing software. In this case by virtue of an angle. Who knows!
Sam Evans
RV7-A O-360 C/S
VAF#812
Old 08-21-2019, 08:45 PM
Ironflight's Avatar
VAF Moderator / Line Boy
For what its worth....Sonex plans are generally dimensioned to the nearest 64th - but I think that is an artifact of doing them in CAD, and having the program dimension the drawing automatically. In discussing things with their “top dawgs”, the nearest 1/8th will probably work fine.
However, it is a challenge to work to tight tolerances, and when you do - things fit together so nicely.....
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 08-22-2019, 05:02 AM
snopercod's Avatar
You guys had it easy. There were many instructions in the Lancair manual reading something like, "Approximately 4-5/64". Stuff like that would drive us builders nuts.
(2019 dues paid)
